Splitting digi signal
Thread Tools Display Modes
Old 07-07-2008   #1
lifes not a practice run
4dbennett's Avatar
My System: technomate diseq 1500ci+ ibm thinkpad
Smile Splitting digi signal
Apologies if this is the wrong forum!
I receive digital tv through a "digital" ariel to a set top box,
can i split this signal to two or more set top boxes??,
if so what effect will the splitter have on reception ??
I,ve used splitters on analogue but don,t know if it will
work on digital
regards dave
4dbennett is offline   Reply With Quote
Old 07-07-2008   #2
Llew's Avatar
My System: Triple Dragon with HDD/USB stick, Humax HDCI2000, Echostar AD3000ip & SR8700, Fortecstar 5100CIUltra, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. Diablo/Mrev Cams
No problem if your signal is good enough (could try an amplifier in the aerial lead if borderline).
Moved thread to appropriate section.
__________________
Llew is online now   Reply With Quote
Old 07-07-2008   #3
4dbennett's Avatar
Thanks Llew would the amplifier need to be before the splitter??
regards dave
Old 07-07-2008   #4
Llew's Avatar
If the amplifier is (preferably) a masthead one, yes, as you need power it through the aerial lead.
Not advisable to have a 'set top' version if your digital signals are on the weak side.
__________________
The Following User Says Thank You to Llew For This Useful Post:
4dbennett (07-07-2008)
Old 07-07-2008   #5
Information Exec
satelliteman's Avatar
Location: South Midlands, UK & Lanzarote, Canary Islands, Spain
My System: 43cm Dish, Sky Plus V2, Thomson DSI6210 Sky+160, Thomson DSI4214, FRACARRO PENTA 85cm, Invacom Twin, Moteck SG2100a H-H DiSEqC Motor, TF5000CI, TM-5200D, Sling Media, Rover ST-4, Rover SDM-1s, 57E to 58W, Tecatel 1.35m fixed on 28e, Pace D5430-N
You can get a 4 way version of a pre-amplifier rather than use a splitter.
This will require a 12V line feed.
Amp goes in main aerial feed, power unit can power on any leg of the amplifier.
Avoid splitters as you get a loss on them unless you have a massive amount of DVB-T signal
__________________
A Detailed DiSEqC Motor Installation Set Up Guide HERE
Motor Installation 'Quick' Reference Guide also HERE
The Following User Says Thank You to satelliteman For This Useful Post:
Old 07-07-2008   #6
4dbennett's Avatar
Thanks Llew and satelliteman, i think i,ll put another ariel up
Regards dave
Old 08-07-2008   #7
rolfw's Avatar
Easier to use an active splitter, use the one satelliteman suggests, it can be powered from any one of the TV points.
__________________
Rolf
Donate
Forum Jump
