how good is the tuner sensitivity of dvb t usb sticks for pc?Information exchange on Freeview, Freeview HD, Digital Terrestrial Television and analogue broadcasts. | |
| Specialist Contributor Join Date: 25-04-2005 Location: Austria
My System: 1,25 Fibostop Jäger Smr 1224 & Smo 36 Dual Axsis Motor Dynasat F1 Monterey 140 Drembox 800 sky Pace HD Box Tagra 2,20 M Fullsize Dish Echostar 2,40m Mesh for cband! |
Hello! i plan to buy a dvb t stick for the pc and laptop,now the offers in the auction house are realy cheap,btween 5 and 7 €,from china the have combination of old alaouge and dvb t together,would be maybe good,outside europe,when iam on holiday,then i can watch analouge tv on the notebook,but how about the tuner sensitivity,are big diffrence,in the quality? are also dvb t sticks avalible that have a normal antenna connector,mostly it is a smaler one for the indoor antenna intslef! the bigest "problem" are the interfering signals,when the signal is inside the house not so strong,from the pc or notbook itself! i plan,to make a plump box,around the pc tower,that i can block the signals so good posible,to make the reception better,i will see how good it works ![]() | ||
| | #2 | |||
| Archived Member Join Date: 13-08-2007 Location: Middle East - Israel
Also in countries that have DTT, the specific country broadcasting specification may not be supported by your USB stick. Consider analogue TV cards (USB) instead. | |||
My System: 1,25 Fibostop Jäger Smr 1224 & Smo 36 Dual Axsis Motor Dynasat F1 Monterey 140 Drembox 800 sky Pace HD Box Tagra 2,20 M Fullsize Dish Echostar 2,40m Mesh for cband! | sure i know that dvb t is digital,on some chinese websites the ofer also combination sticks for analog tv also,i have usb tv card here from hauppauge,when i take this with me outside euorpe i can watch,also the only avalible analouge signal in asian countrys,over this card ! | ||
| Check which countries you are likely to visit have DTT and their broadcasting system. If no country has DTT, then there is no point in taking the gadget with you. | ||
| | #5 | |||
What will you do, adapt your suitcase to take the required large aerial.. ..don't forget the same principle applies with digital terrestrial as with digital satellite. A strong signal is required for a lock....it is either there or not with analogue you can put up with a snowy picture, with digital you will not get anything as the required threshold is higher with digital | |||
| dvb, good, sensitivity, sticks, tuner, usb |
