Panasonic CRT TX-28DTX10 tuning problems post retune day
Information exchange on Freeview, Freeview HD, Digital Terrestrial Television and analogue broadcasts.
Old 08-10-2009   #1
rolfw's Avatar
Real name: Rolf
Went to see a suspected aerial problem today, the above TV would not tune the BBC multiplex on channel 50 from Hannington.
Tested on the meter, good signal at 47db all excellent quality readings. The owner phoned Panasonic who are sending out a card to plug into the back (not sure which type), but it will make up for the lack of updates to the set, which had auto updates enabled, but the software for some reason hadn't updated.
The problem is caused by the old software having a preset limit on the number of channels which can be stored, an update will change the parameter and allow for a full channel scan.
So for anyone else with a similar problem, it may well be your TV's software.
Rolf
Old 08-10-2009   #2
My System: IP9000HD twin HD tuner operating > Triax TD110 Dish & 80cm FaVal Dish working in Tandem 60degEast to 60degWest Humax HDCI2000 operating > VboxII & 1.8 m Alcoa PF dish + Pauxis C-Band lnbf... Skystar2 /Twinhan SD /TS S2-3200 pci cards
Hi Rolf ...
I had a similar problem on a different brand of TV a few weeks back ...
The solution came in the form of an update for the sets freeview firmware on a specially prepared compact flash card ..
The card of course could not be plugged directly into the TV ...but required obtaining a pcmcia to compact flash adapter..
This could then be plugged directly into the cam slot 'assuming your set has one' ...
The upgrade process was then fully automated ...as the set reads the firmware on power up..
I suspect yours might require a similar operation.
rgds
VS
ps ...If you manage to get hold of this card ..
any chance you could grab a copy of the contents ?
usually a binary or executable file ..
I have no doubt I will need this flash myself at some point in the course of my job..
once I have the firmware ...I can write my own upgrade card for this model..
cheers
Vipersan is offline   Reply With Quote
Old 09-10-2009   #3
rolfw's Avatar
Real name: Rolf
Apparently it is a PCMCIA module, which carries the appropriate software. If I have time to get a look I will, but it may not be possible, the customer I believe will be asked to return the CAM after use.
Rolf
The Following User Says Thank You to rolfw For This Useful Post:
Vipersan (09-10-2009)
Old 09-10-2009   #4
Sky Remote Breaker...
2cvbloke's Avatar
My System: Mostly gathering dust cos there's no room for dishes here... :(
The Sleepy Hollow pollracle has spoken!
Probably what our sony IDTV needs, though I have yet to hear back from them about it...
I think your car looks funny too......
Proud owner of a satellites.co.uk cap & T-Shirt...
(though the latter no longer fits due to my ever expanding waistline!!!)
Resident KIRBY Vacuum nut...
2cvbloke is offline   Reply With Quote
Old 16-10-2009   #5
kenny1234's Avatar
My System: Motorised ASC 1.2m,1224 Supermount with C120 Invacom Quad LNB with Matched Feedhorn.
I ve just called to one of my customers who has a panasonic tv, whilst I was there he contacted panasonic direct they informed him that on Monday at 11.50am on BBC 1 a software upgrade will be run to cure the problems as such a back log of peeps wanting a cam.
Nice of them only prob round here is BBC channels are the last ones to be picked up so tuner drives straight past and doesn't store them.
It's a case of trial and error removing the aerial from the back of the set to miss a multiplex thus allowing BBC to be added
kenny1234 is offline   Reply With Quote
Old 18-10-2009   #6
Mod and septic resident
Channel Hopper's Avatar
All older Panasonic/Quintrex TVs will have the same problem, as do the TUCT 20-40 boxes.
It may still nt be possible to put the channels in the right order after upgrading.
For 15 quid and a trip to Argos, they could get a new fangled Freeview jobbie for their TV, no installer/Cam upgrade required.
Old 19-10-2009   #7
2cvbloke's Avatar
Just for the heck of it, I've set our Sony TV to BBC1 too, so, I dunno, maybe there'll be a Sony update too, doubtful though...
Old 19-10-2009   #8
kenny1234's Avatar
There are some sony download's next week see below
_http://www.dtg.org.uk/industry/download_schedule.php
Old 19-10-2009   #9
2cvbloke's Avatar
Hmm, none for the KD-28DL10U, probably "too old" for them to fix...
crt, day, panasonic, post, problems, retune, tuning, tx28dtx10
