A solution for old tellies...
Information exchange on Freeview, Freeview HD, Digital Terrestrial Television and analogue broadcasts.
Old 17-10-2009   #1
Sky Remote Breaker...
2cvbloke's Avatar
My System: Mostly gathering dust cos there's no room for dishes here... :(
The Sleepy Hollow pollracle has spoken!
Here's something that might interest those with older TVs with no AV function that are threatened by the switchover;
A Sony Playstation (original grey box one) RFU Adaptor!!!
All you need is a couple of Phono leads with plugs on one end and sockets on the other and a 5vDC power source, and you can use the adaptor as an RF modulator for anything that uses only AV out, such as cheap freeview boxes...
It's only limited to UHF Channel 36, which was often the one used by VCRs, but after the switchover, I don't think that would matter (as long as there are no MUXes on 36!!!)...
Just need to find myself a 5v source, and I'll try it out...
A solution for old tellies...-hrfuadaptor-jpg
I think your car looks funny too......
Proud owner of a satellites.co.uk cap & T-Shirt...
(though the latter no longer fits due to my ever expanding waistline!!!)
Resident KIRBY Vacuum nut...
2cvbloke is offline   Reply With Quote
Old 17-10-2009   #2
Mod and septic resident
Channel Hopper's Avatar
I recall a number of service calls, where the TV in question was unable to receive any digital signals. Once on site, it was often a case of disconnecting the adaptor from the kids room TV and handing a 25 pound callout charge to the houseowner.
Things have changed, I now charge 40 quid.....
Old 18-10-2009   #3
2cvbloke's Avatar
Hehe, easy money eh?
I also have a switch thing that you plug the device into, then you can switch between the Aerial input or the Modulator input...
Though, how would an adaptor like that stop digital TV appearing on the TV? Or were the boxes also set to CH36?
Old 18-10-2009   #4
BombedOne's Avatar
My System: Covering 30W-105.5E range, two motors, C and Ku band. Various receivers/cards/cams/etc.
Yes, this is good solution.
Also to be noted, if you'll make minor circut adjustments, you can make SCART<>S-Video adaptor from that box.
BombedOne is offline   Reply With Quote
Old 18-10-2009   #5
satelliteman's Avatar
Real name: Paul
Also these and similar devices can be lossey and enough to drop off the cliff if the signal is marginal.
satelliteman.
An Installers Choice
Follow us on
Old 18-10-2009   #6
Not just the loss, as soon as the games station is powered from the mains (even in standby), the modulator is running and this generates noise over the whole spectrum.
Old 18-10-2009   #7
Real name: Paul
Yes because of a cheap DSB modulator used thus will create side bands ie. N+/-1, N+/-5 within the uhf spectrum. In high signal areas cross mod / intermodulation distortion can occur.
Lets get all technical
satelliteman.
Follow us on
Old 18-10-2009   #8
2cvbloke's Avatar
Interesting, but, come switchover, there's no need to have an aerial plugged into the old analogue TV (so no requirement for anything to be plugged into that pass-through socket), so, how would the UHF interference get from modulator to STB??
Old 18-10-2009   #9
rolfw's Avatar
Real name: Rolf
Some of the newer Freeview boxes have a built in modulator, the TVONICS MFR 300 is one example. I believe that there is a Ferguson which has a modulator as well.
Yes you are right 2cv, shouldn't be a problem come switchover.
Rolf
Old 18-10-2009   #10
Real name: Paul
Yes also there are a few freeview receivers around with 4 connections ie. separate loop through and RF mod out
satelliteman.
Follow us on
Old 18-10-2009   #11
2cvbloke's Avatar
I'm happy with my Oggle boxes, despite the switchover attempting to kill them off, they work great, they just lack a modulator...
If I buy another freeview box, it'll have to be another Oggle...
Speaking of a Ferguson, my portable kit I'm selling has a stand-alone Tuner/Timer unit that could act as a modulator, seeing as the VCR unit needs "attention" (belts maybe?), then the TTU could be useful to some:
Ebay 230388359625
(shameless plug, I know, but it is terrestrial related, sort of!!!)
I still need to find a 5v source though, found a 2.5mm socket for the plug, just need a PSU now...
Old 18-10-2009   #12
kenny1234's Avatar
My System: Motorised ASC 1.2m,1224 Supermount with C120 Invacom Quad LNB with Matched Feedhorn.
Manhatten freeview receiver also has modulator cracking box @ around £25
kenny1234 is offline   Reply With Quote
Old 1 Week Ago   #13
My System: AB IPbox 9000HD, only a fixed dish for now..
Another I think better solution would be to get a UHF modulator from a supplier, the likes of CPC
_http://cpc.farnell.com/labgear/mod111/uhf-modulator/dp/AV13328
This one costs about £36, a bit expensive, but I guess ygwyp4 ! (you get what you pay for!) Be careful buying cheap Freeview boxes, most have no modulator.
2cvbloke: these people also do small power supplies.
There are other suppliers available (that keeps the MadMen happy!)
bobdisk is offline   Reply With Quote
Old 1 Week Ago   #14
2cvbloke's Avatar
I've still yet to go through my bag of extensive electrical crap that I really should sort, all I need now to get my Playstation modulator running is the 5vDC supply, soon I hope, very soon...
Old 1 Week Ago   #15
Manic Midlander Moderator
nanochickin's Avatar
My System: Dreambox 7020si, Technomate TM600, Technomate TM9100 Fracarro Penta 85 Dish, Televes 0.6dB Quad lnb, TM SG2200 motor. 60cm Channel Master BSB dish on 28e, Mti Blueline 0.2db Twin Lnb. Rover ST-4 Meter Cyfra+ Subscription
I just use one of these. Works really well
_http://www.vision-products.co.uk/productpage.asp?productcode=V40-104&subcategoryid=62
Nano
A solution for old tellies...-v40-104a-jpg
Sanity is nothing more than an excuse to be boring
<<<<<<<<****** Dreambox DM7020 Si , S.I.F 1.9.3d ******>>>>>>>>>
<<<<<<<<******** Technomate TM9100, EDG 4.4 ******** >>>>>>>>
<<<<<<<<<<******* Technomate TM600, UR 23 *******>>>>>>>>>
nanochickin is offline   Reply With Quote
Old 1 Week Ago   #16
rolfw's Avatar
Real name: Rolf
For most people, buying a Freeview box with a built in modulator will be the cheapest and easiest option.
Rolf
Old 1 Week Ago   #17
2cvbloke's Avatar
Yep, but for the likes people like me who have other things, and like to tinker, then making something is more fun...
Old 6 Days Ago   #18
Only problem is fewer manufacturers are putting modulators in these days, especially cheapos
solution, tellies
