Help - 0 channels found on Pioneer Box!
Information exchange on Freeview, Freeview HD, Digital Terrestrial Television and analogue broadcasts.
Old 13-03-2002   #1
negg
Posts: n/a
Hi.. I moved a Pioneer Terrestial box from London to Surrey 6 months ago. Auto search found all channels again and was a.o.k.. Moved back to London few days ago - same house and aerial connection as 6 months ago when it worked... now auto search on the box gets to 25% and say '0 channels found' with the little red box on the screen indicating no or poor signal. The aerial is fine as the video gets a great picture with the same cable.
Is the box busted?? Would a factory reset help and if so how is one done on the Pioneer??? Is there a limit maybe on doing these searches to stop people taking their boxes to different locations without telling ITV???
Old 18-03-2002   #2
tallest_of_paul
Posts: n/a
RE: Help - 0 channels found on Pioneer Box!
[updated:LAST EDITED ON 18-Mar-02 AT 00:16 AM (GMT)]My mate lives in a poor reception area, so he has a booster before going into the box (Nokia). The only problem is, if he needs to "store channels" the box doesn't find any! Yet it can watch stored channels no problem, he brought his box round to mine the other night just to update with the new channels.
Point being... have you got a booster in line with the arial? Try getting a direct signal from the arial, if this doesn't work then afraid it sound's like your box is bust for sure. Don't know how to reset software (try holding select when powering up(works with philips)).
Good luck either way.
Tallest
Old 18-03-2002   #3
Overclocker Supreme & General Mad B*st*rd
Burnt Chips's Avatar
In menu has the signal strength meter moved (ie has a green bar appeared)if not try ajusting rf channel (usually 21-89)try all and see if a green bar apears.(i had same prob this cured).
DAVE
Burnt Chips is offline   Reply With Quote
box, channels, pioneer
Similar Threads
French Channels RogerP Sky Digital (BSkyB) and Astra 28.2 East General 15 17-03-2006 05:20 PM
English Audio on satellite channels cowboy Transponders & channels 11 23-02-2006 01:08 AM
SkyStar2 - what channels on Astra 19.2E ? Rod Hulls Aerial Satellite PC Card Receivers & Internet by Satellite 9 01-03-2004 09:08 PM
Star channels in Sky Family net1 Sky Digital (BSkyB) and Astra 28.2 East General 0 26-01-2004 02:06 PM
Erotica channels launch. net1 Adult satellite channels 0 24-06-2003 07:38 PM
