ARY Digital (Sound problems)Where can I find Satellite Transponders & channels? TPX/channel/feeds: changes, sightings & questions | |
| No1 Satellite Thick Idiot Join Date: 01-01-2000 Location: London UK
My System: Sony KLV26HG2 LCD TV, Humax HD-CI 2000 on a Fixed Sky/Astra/Hotbird. Cerebro Card. Infinity USB Phonix. Dragon Cam v4.1 w/Firecrypt & Loader Card. |
I am getting a crackle sound in the background of channel ARY Digital. Please I would be greatful if you have the same problem. All other channels are fine. Thanks in advance Shahid | ||
Yes, it is on Hotbird I am watching it. So are you spound problems with ARY Digital on Hotrbird. It's a continous crackling sound. Many thanks in advance. | ||
| | #5 | ||
Assuming its not the crusty bed linen making the noise 1) check you dont have any problems from a similar soursce on the same transponder (eg 2M Maroc). If so go to 3) 2) Check the receiver has loaded the correct audio PID from the bouquet, Ary has decimal value 651 (hex is 28B). Correct if wrong in the manual advanced install section of the menu, then go to 3). 3) Delete the transponder completely , switch off and on, and re install 4) Edit the Audio PID up or down by one or two digits to see if the MPEG filter is collecting all the available information from the stream. | ||
| There is a very fine line between "hobby" and "mental illness" | |||
| ary, digital, problems, sound |
Similar Threads | ||||
| Signals, noise, digital errors ... all that stuff. | spiney | Members' input on FAQ and How To's | 0 | 02-04-2006 04:41 PM |
| HDTV Primer | spiney | High Definition Receivers transmissions, satellite and Terrestrial | 0 | 16-01-2006 12:42 PM |
| Transponder update 10/07/03 | Satdude | Transponders & channels | 3 | 01-01-2005 10:24 AM |
| Digital Britain: the Ofcom report | net1 | Terrestrial Television, Digital and Analogue | 0 | 23-02-2004 05:40 PM |
| IFA 2003 Berlin exhibition report | net1 | Digital systems | 0 | 01-10-2003 08:02 PM |
