Remote control codes for TD | | My first post here, hope somebody can help. Recently purchased an Archos 5 portable device for recording from sat receiver, dvd and internet. The archos has a docking station which has an infra red emitter capable of changing channels on tv's and satellite receivers. There is a list of satellite receivers on the Archos (about 100) but the TD isn't listed. It would take hours trawling through all the available remote control IR codes to find one that worked with the TD and I wondered if anybody knows the range of IR codes used by the TD or if the TD remote IR codes are compatible with any other more common receivers?
Thanks for any help |
