On the edge...Help and support for Triple Dragon linux satellite receiver, The New kid on the block. | |
| Member Join Date: 12-02-2006 Location: Bremen Germany
My System: GoldMaster 9400V CI, ZetaCAM red, Orion Dream, 80cm @ Turksat, 80cm @ Hotbird |
So, here I am on the edge of getting a TD (actually I tried to order one from LinuxFTA and their order form messed up). After I break it out of the box and connect it, then what? Is the first thing I need to do is install another image, or just add the CAM emulators and latest keys. One of the reasons I am going with a Linux based receiver is I was told that I can have it auto update the keys off the internet. Is that true, or have I been mislead? If it does work like that, is there a fee for such a service, or is it one of the benefits of having great friends around? Enough for one post... Thanks, Joe | ||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | Hi Joe Hope you decide on the TD, a great box to play with. The guides in this section should help to get you started. Don't know how you intend to connect to the PC/internet (router or LAN cable to your PC), but once you are cabled up, I suggest you use one of the TD Tool programs to update the image that will be provided on your TD with one of the unofficial images available from the various TD sites that provide these. I would suggest the 'TDMan' images for this purpose,as they are regularly updated, and easy to add keys etc. using an FTP program (one of the TD tools, TDCC, has this function included). Yes, autoupdate works, provided a current URL address that uploads the latest keys is working in the image file. AT present, the 'Tee Pee Ess' bouquet is clear on the TD this week without the need for a regular internet update if you have the right file loaded. Regards, Llew | ||
| edge |
