Dear Technical Support
Got a joke? Why not share it. Please observe the forum language guidelines.
Please do not enter if you are easily offended.
Old 18-10-2005   #1
Head Honcho
chris's Avatar
My System: Philips 42" Plasma TV, Amstrad Sky digibox, XC Cube windows media centre PC.
Dear Technical Support,
18 months ago, I upgraded to Girlfriend 1.0 from DrinkingMates 4.2,
which I had used for years without any trouble. However, there are
apparently conflicts between these two products and the only solution was to
try and run Girlfriend 1.0 with the sound turned off.
To make matters worse, Girlfriend 1.0 is incompatible with several
other applications, such as LadsNightOut 3.1, Football 4.5, and Playboy 6.9.
Successive versions of GirlFriend proved no better.
I tried a shareware program, Slapper 2.1, but it had many bugs and
left a virus in my system, forcing me to shut down completely for
several weeks.
Eventually, I tried to run GirlFriend 1.2 and Girlfriend 1.0 at the
same time, only to discover that when these two systems detected each other
they caused severe damage to my hardware.
I eventually upgraded to Fiancée 1.0, only to discover that this
product soon had to be upgraded further to Wife 1.0. While Wife 1.0
tends to use up all my available resources, it does come bundled with
FreeSexPlus and Cleanhouse2005.
Shortly after this upgrade, however, I found that Wife 1.0 could be
very unstable and costly to run. Any mistakes I made were
automatically stored in Wife 1.0's memory and could not be deleted. They
then resurfaced
months later when I had forgotten about them. Wife 1.0 also has an
automatic Diary, Explorer and E-mail filter, and can, without warning,
launch TurboStrop and Multi-Whinge. These latter products have no Help
files, and I have to try to guess what the problem is.
Additional problems are that Wife 1.0 needs updating regularly,
requiring ShoeShop Browser for new attachments and Hairstyle Express
which needs to Be reinstalled every other week. Also, when Wife 1.0 attaches
itself to my Saab 93 Convertible hard drive, it often crashes.
Wife 1.0 also comes with an irritating pop-up called MotherInLaw, which
can't be turned off.
Recently I've been tempted to install Mistress 2003, but there could
be problems. A friend of mine has alerted me to the fact that if Wife
1.0 detects Mistress 2003, it tends to delete all of your Money before
uninstalling itself.
Need a
Satellite Installer
in your area ?
Click Here
chris is online now   Reply With Quote
dear, support, technical
Similar Threads
Conax plans to set up unit to support CAS in India net1 Indian Subcontinent General Section 6 17-08-2006 05:52 PM
Dear Tech Support kleefarr Wavey's Jokes Corner (May contain nuts) 4 27-04-2005 04:49 PM
JVC TU-DB1 a word of warning - technical support mrfreeview Terrestrial Television, Digital and Analogue 0 13-01-2005 08:52 PM
Freeview manufacturers may not support 7-day EPG net1 Terrestrial Television, Digital and Analogue 0 23-01-2004 08:43 PM
