7 Kinds Of Sex.......... | |
| Member Join Date: 13-05-2006 Location: Oslo, Norway
My System: Channel Master 2.4m Ground mounted with an Invacom 0.3 Dual feed LNB C120 fitted Channel Master feedhorn Panasonic DS30 with complete SKY package Technomate TMS1500 ci for FTA (BBC + ITV) |
Recent research shows that there are 7 kinds of sex: The 1st kind of sex is called: Smurf Sex. This kind of sex happens when you first meet someone and you both have sex until you are blue in the face. The 2nd kind of sex is called: Kitchen Sex. This is when you have been with your partner for a short time and you are so horny you will have sex anywhere, even in the kitchen. The 3rd kind of sex is called: Bedroom Sex. This is when you have been with your partner for a long time. Your sex has gotten routine and you usually have sex only in your bedroom. The 4th kind of sex is called: Social Security Sex This is when you get a little from time-to-time, but not enough to live on. The 5th kind of sex is called: Catholic Sex. This is when you get Nun in the morning, Nun in the afternoon and Nun at night. The 6th kind is called: Hallway Sex. This is when you have been with your partner for too long. When you pass each other in the hallway you both say "screw you." And last, but not least, the 7th kind of sex is called: Courtroom Sex. This is when you cannot stand your wife any more and she takes you to court and screws you in front of everyone. | ||
