Nokia 9800 Tuner replacementFor those who wish to discuss the more technical aspects of Satellite receivers and TVs. perhaps how to replace components, fault finding etc. | |
| Specialist Contributor Join Date: 25-04-2005 Location: Austria
My System: 1,25 Fibostop Jäger Smr 1224 & Smo 36 Dual Axsis Motor Dynasat F1 Monterey 140 Drembox 800 sky Pace HD Box Tagra 2,20 M Fullsize Dish Echostar 2,40m Mesh for cband! |
hello! yesterday,my 9800 is crashing from the table,and the lnb input of the tuner is broken.. so iam looking ,for a single ,tuner @ the moment... is it dificult to replace inside? | ||
| Member Join Date: 28-12-2007 Location: Martinique
My System: ---------------3.8m C band H-H motorized dish, Houston Tracker HTS-8+ analog positionner, Praxis 9800-Ci, DSR905 4Dtv, -------1.8m Ku motorized dish, C120 Invacom Lnb, Moteck Vbox II, Clarke-tech 1500----------- Clic the dish to see pictures. | Hello, Because you get no answer until now, here is mine. Usually it is easier to repair the F-connector on the tuner than remove it from the main board. You need to remove entirely the main board from the cabinet, so you can open the tuner. | ||
| 9800, nokia, replacement, tuner |
