Wiztech 222 Remote problems
For those who wish to discuss the more technical aspects of Satellite receivers and TVs. perhaps how to replace components, fault finding etc.
Old 29-09-2008   #1
My System: Computer win 98 pentium 2 Satellite from PAS7/10 Also Arabsat C Band Fortec Lifetime and Wiztech 260
Question Wiztech 222 Remote problems
Hi guys
Have a 222 and will not accept remote.Bought new remote.. same.
Changed the face and board with another from working unit... still no go
Any ideas?
Also any news on the loader program for these .
Last I found was for the 260 A
Any help appreciated
alanzim is offline   Reply With Quote
Old 12-10-2008   #2
My System: turnkey 700mhz athelon .5gb ram,120 gb,drive j-test j-tag setup
have you re-flashed the wiz??
if the remote works with oem bin,it could be a compatibility
issue with a different bin.
boxnut is offline   Reply With Quote
Old 06-11-2008   #3
My System: Wiztech 220 F
Incorrect Remote
Hello,
I had a same problem, then dicovered that the the new remote did not have the same code as the old one.
The idea is to find another 222 that was manufactured at the same period as yours. Try that remote control, it should work.
Regards
Cal
caljay is offline   Reply With Quote
222, problems, remote, wiztech
