USB - RS232 Adapter | |
| Member Join Date: 04-11-2007 Location: Ireland NW
My System: FTA Stationary Dish FTA Receiver |
Hi All, I hope I'm posting on the correct forum and would appreciate any help or suggestions. I recently purchased a Dynamode USB-RS232 Serial Adapter with the intention of uploading software updates from my laptop(XP OS) to my technomate receiver. Unfortunately the driver supplied on the cd is not being recognised by my laptop because it is not digitally signed. Does anyone know how I can get around this problem? Cheers Mac | ||
| Dazed and Confused Mod Join Date: 28-06-2003 Location: Wirral, NW England
My System: Various digiboxes, broken Nokia 9800S, numerous analogue boxes. My lovely little lappy, HP Omnibook 6100 | When you get the warning about the digital signing you normally get the option to continue anyway - try clicking that. If not, what exactly does the warning messsage say and what are the options? | ||
My System: Various digiboxes, broken Nokia 9800S, numerous analogue boxes. My lovely little lappy, HP Omnibook 6100 | If you get the driver recognised I'd be interested to know whether the RS232 doe its work properly - I've heard that these don't often work properly. | ||
| Member Join Date: 10-11-2008 Location: Hungary
My System: GLOBO 6010 CI Illusionsat M5 W4-5 ; W0,8-1 ; E4,8-5 ; E13 ; E19,2 ; E23,5 ; E28,2-28,5 | Hy Mac1170 , I use UC-232A adapter. It is a very good. You need buy this type, or a model with IC [UC-232A]. I'm sure it will be work. Stubyte | ||
| | #5 | ||
My System: FTA Stationary Dish FTA Receiver | Thanks for the replys folks! When I first install the driver I receive a warning message that the HugePine USB to serial port has not passed the windows logo testing to verify its compatibility with Windows XP. I then continue to install the device. When I check the hardware device manger properties it tells me the device is not working properly. I've tried to find the 'correct' driver on the net but to no avail. Its a tad frustrating but not the end of the world. I'm really just curious to discover if the software update to my technomate will enhance its otherwise good performance. Cheers Mac. | ||
| | #6 | ||
My System: TM6800HD, TM1000, TM600 Linux,TM5200, TM2200 motor, Triax TD110 dish + Fortec 85cm. Meter=Satlook Micro+G2 NIT | Which Technomate receiver is it? I take it that you have actually plugged the device in?. I have used one of those devices which uses a driver of that name on a Laptop running XP and it did work alright most of the time. I no longer use it now though, as a USB stick or a serial port is much simpler. | ||
| | #7 | ||
| Member Join Date: 01-01-2008 Location: A
My System: echostar,edi IBM P4 | If you have a COM connection use a serial cable that works much better.Never use USB connection longer than 1.5 meters, sometimes arepeter works and dont use a distingution (sorry I think its not correct english, I mean 2 cables) | ||
| | #8 | ||
My System: Various digiboxes, broken Nokia 9800S, numerous analogue boxes. My lovely little lappy, HP Omnibook 6100 | | ||
| | #9 | ||
| Regular Member Join Date: 31-05-2006 Location: glasgow
My System: 1.2m motorised qualitv decoder manhatten blind search decoder echostar 3600ip | I've used a convertor with my laptop to upgrade a darkbox and it works a treat.The only prob is finding the correct com port.It may take a few attempts but it will work. | ||
| | #10 | ||
Blog Entries: 1 My System: Sky UK. FTA analogue & digital satellite from 6 fixed dishes (5E/7E/9E/10E/13E/16E/ 19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S ![]() The last noble sat warrior to fly the olden flag of Analogue | Ive got a usb to serial converter for my little weather station. The weather station only recognises the first 4 com ports so you have to do a bit of com port fiddling to get everything running correctly, but it works fine. | ||
| | #11 | ||
My System: FTA Stationary Dish FTA Receiver | The Technomate I'm using is the TM 1500 CI +Super. After a bit of fiddling with my settings the laptop is now recognising the device as working properly although the technomate TM Loader software won't upload the software. When I select connect I just get a message telling me to turn on the receiver (which I do) and then nothing happens. Any suggestions welcome please! Thanks Mac. | ||
| adapter, rs232, usb |
