The Dreaded SetPal scam - spare parts ?For those who wish to discuss the more technical aspects of Satellite receivers and TVs. perhaps how to replace components, fault finding etc. | |
I wasn't sure where to put this post but here goes. I have a couple of Daewoo DS608s which were absolutely brilliant in operation before prompted for a channel search. ![]() I used to use them on installs owing to the 'analyser' menu which was quicker for the customer to acknowledge than the meter when it came to suggesting a new aerial was in order. The technical side of the issue _http://www.avforums.com/forums/8180512-post21.html And a good description of what happened in many homes last year _http://www.variety.com/article/VR1117990650.html?categoryid=1019&cs=1&nid=2562 Now they might as well be consigned to the bin as no information seems to exist on a full factory reset beyond the software and back panel button. On both machines, giving them an intermittent jump from the mains does bring back the OSG and signal reading within the 'preference' menu, but this is lost as soon as the 'cancel' button is pressed (starting the Easytune setup, at the root of the tuner/modulator lockup) Does anyone here know of any trick to give them some life again, if only to use the signal meter part ? | ||
| There is a very fine line between "hobby" and "mental illness" | |||
| Specialist Contributor Join Date: 09-09-2008 Location: Republic of Georgia
My System: Covering 30W-105.5E range, two motors, C and Ku band. Various receivers/cards/cams/etc. | Open it, find the eeprom chip (not main flash where firmware is stored). Check the manual for that chip. Some of them can be reset if certain pin shorted to ground. | ||
| Thanks Nearest to the eeprom of this box is a Spansion chip Details of something similar (not the S29AL016W90A101 that is on the PCB) _https://www.eetools.com/index.cfm?fuseaction=devices.show_details&Device_I D=13765&Programmer_ID=0&Programmer_name=TopMax2 No reset point that I can see on the board, and tbh the distance of the pins is rather too close to short out with a needle - there are 24 pins each side of the IC, each one is less than 0.5mm apart. Even reading the chip number was a task under good light. Btw, main chipset of the box is ST _http://content.pace-twin.org.uk/datasheets/STI5518BVC-MAIN-PROCESSOR/STI5518.pdf | ||
| dreaded, parts, scam, setpal, spare |
