Echostar AD-3000IP ProblemFor those who wish to discuss the more technical aspects of Satellite receivers and TVs. perhaps how to replace components, fault finding etc. | |
| Member Real name: Ray Join Date: 05-05-2009 Location: Tadworth, Surrey
My System: Echostar AD-3000IP Toshiba Satellite X200 plus others |
Hi, not sure if any of you guys can help - my Echostar died over the weekend, seems to turn on OK but the lights just revolve continuously when coming out of standby. Echostar site suggests loading latest code ( was already loaded ) but reloading made no difference. Followed hints and tips on your site using both sets of schematics - found R3 well cooked but resoldering made no difference. DVM suggest all voltages OK. Checked ripple with scope, again appears fine - very little noise. Tried to get Echosat ( only authorized Echostar repair agent? ) to quote to be told their only engineer on holiday till May 27/28 ( and I thought I had it tough! ) Any thoughts would be appreciated - rgds Ray aka mihd | ||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | That's most likely to be a corrupt eeprom. If reloading firmware doesn't work, the only course is replacement, as I don't think there's any method that you can access the eeprom to erase and reprogram it through jtagging the CPU on this machine. Best to get Echosat to look at it, as you say. Llew | ||
| ad3000ip, echostar, problem |
