Driving a large dish with DiSEqC ReceiversFor those who wish to discuss the more technical aspects of Satellite receivers and TVs. perhaps how to replace components, fault finding etc. | |
| Member Join Date: 26-07-2006 Location: Eastern England. UK
My System: Technomate TM6900 Combo. 160G HDD 1.2Mtr Channel Master dish & Polar mount, T-REX/ Diablo CAM/ CAS3. Sony Bravia HD |
Hi All After retiring my trusty old AD3000 I wanted to use my old 1.2 Mtr Channel Master dish and polar mount with my new TM6900 Combo, So I had to find a suitable actuator to drive my dish but didn’t want a V box plugged in and on show under my new Sony Bravia. I decided to try a Superjack DiSEqC DG100 actuator, which was supposed to be ok driving a 1.2 mtr dish, I had loads of problems with it ignoring commands and not moving properly. I have come up with a solution, by stripping the PCB out of the actuator fitting it in to a box with a power supply to feed the motor instead of the receiver trying to power the dish; this was fitted and powered from my garage near to my dish. So now the PCB’s motor output is only driving 2 relays through an arrangement of diodes, the motor supply is a simple mains transformer and rectifier switched on by the relays so is only energised when a movement command is received, this has allowed me to refit my 18 inch heavy duty Superjack actuator back on the dish and is running faultless because there is no load on the receivers power supply now. Bellow is some photos of the install and a circuit diagram. | ||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | Excellent idea SST12. A pity there's no 12V output option on that receiver, then the power supply could be installed indoors (for those who have no supply local to the dish) and switched on by a 12V relay operated by the receiver. Assuming a motor cable to the dish is already in place to supply your unit. If no 12V facility on the receiver, have the power supply (minus the relay) switched on in tandem with the receiver via a mains socket strip. Llew | ||
| The Following User Says Thank You to Llew For This Useful Post: | SST12 (11-05-2009) |
My System: Zone1, DSI8215 SkyHD, Thomson DSI4214, TF5000CI, Dreambox DM800 HD PVR - Nab BH0.12, TM-5200D, Gibertini 104cm, SNH-031, 36v Actuator, Vbox-II, 42°E to 30°W, Sling Media, Televes H45 Digital Processing Analyser, Satlook Micro+G2 NIT, Rover SDM 1s | Good job there, neatly laid out in pic 3 | ||
| The Following User Says Thank You to satelliteman For This Useful Post: | SST12 (11-05-2009) |
| Specialist Contributor Join Date: 11-09-2008 Location: 38.5ºN, 0.5ºW
My System: Gibertini 1.5m, Jaeger 1224, Vantage x221 TS CI... Fibo 90, Mot-Sat3, Manhattan Plaza XT-M... Satcatcher Excel-TV, Lacuna Mk4 | | ||
| | #5 | ||
My System: Technomate TM6900 Combo. 160G HDD 1.2Mtr Channel Master dish & Polar mount, T-REX/ Diablo CAM/ CAS3. Sony Bravia HD | Hi Huevos That would mean purchasing a V Box, this was made from the spare parts bin. The mains side of the power supply is only energised on dish movement, A V box has a power supply on all the time. | ||
| | #6 | ||
| Sky Remote Breaker... Join Date: 05-01-2006 Location: Near Pendle Hill, Lancashire
My System: Mostly gathering dust cos there's no room for dishes here... :( The Sleepy Hollow pollracle has spoken! | Very nice work indeed, and parts from the bin, a nice bit of recycling too... | ||
| I think your car looks funny too...... Proud owner of a satellites.co.uk cap & T-Shirt... ![]() (though the latter no longer fits due to my ever expanding waistline!!!) Resident KIRBY Vacuum nut... ![]() | |||
| The Following User Says Thank You to 2cvbloke For This Useful Post: | SST12 (11-05-2009) |
| | #7 | ||
| Nicely done, better than throwing out the old stuff. | ||
| There is a very fine line between "hobby" and "mental illness" | |||
| The Following User Says Thank You to Channel Hopper For This Useful Post: | SST12 (11-05-2009) |
| | #8 | ||
| Dazed and Confused Mod Join Date: 28-06-2003 Location: Wirral, NW England
My System: Various digiboxes, broken Nokia 9800S, numerous analogue boxes. My lovely little lappy, HP Omnibook 6100 | | ||
| | #9 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | Excellent job, well done. | ||
| diseqc, dish, driving, large, receivers |
