Removing RF tuner whatsits...For those who wish to discuss the more technical aspects of Satellite receivers and TVs. perhaps how to replace components, fault finding etc. | |
| Sky Remote Breaker... Join Date: 05-01-2006 Location: Near Pendle Hill, Lancashire
My System: Mostly gathering dust cos there's no room for dishes here... :( The Sleepy Hollow pollracle has spoken! |
Just a thought... ![]() With the switchover looming here in the Granada region (November), I was wondering what to do with my old TVs that have no AV facility, one being an old girly (pink accents and a heart tip on the aerial) Toshiba TV and the other being my old handheld Citizen CT555 (I think)... ![]() Now, my thought is that an RF tuner thingy, at a guess (I'm no expert!!! ![]() But of course, this is just my mind working overtime... | ||
| I think your car looks funny too...... Proud owner of a satellites.co.uk cap & T-Shirt... ![]() (though the latter no longer fits due to my ever expanding waistline!!!) Resident KIRBY Vacuum nut... ![]() | |||
| | #2 | |||
| Archived Member Join Date: 13-08-2007 Location: Middle East - Israel
At least you have a working TV now, so why ruin it? It would be easier to use an AV - RF Modulator converter than the other way round. Have you checked if the the new system doesn't have an RF output, in addition to AV? | |||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | Most UK Freeview boxes don't have built in RF modulators, only RF loopthroughs. You can buy an RF Modulator for between £10 and £20, loads of them on Ebay | ||
| Save your money and use an old video recorder as the modulator. The tape mechanics of the box don't have to be working either. Sky cunningly left out the AV loop from their boxes so they cannot be used for connecting anything else to the television. | ||
| There is a very fine line between "hobby" and "mental illness" | |||
| | #5 | ||
My System: Mostly gathering dust cos there's no room for dishes here... :( The Sleepy Hollow pollracle has spoken! | The problem with the RF-AV modulators it that my Citizen handheld has no inputs for external peripherals, which is why I'm thinking of the modifications... | ||
| | #6 | |||
| If you have an RF modulated output, connect it to the aerial socket and tune the RF to the same frequency as the RF modulated. (VHF or UHF, depending on the source) Try this with a VCR output or any other source. | |||
| | #7 | |||
My System: Mostly gathering dust cos there's no room for dishes here... :( The Sleepy Hollow pollracle has spoken! | ![]() In the past I have wrapped an RF cable's core round the aerial, and that seemed to work, but was fiddly to hold in place... | |||
| I think your car looks funny too...... Proud owner of a satellites.co.uk cap & T-Shirt... ![]() (though the latter no longer fits due to my ever expanding waistline!!!) Resident KIRBY Vacuum nut... ![]() | ||||
| | #8 | ||
| Dazed and Confused Mod Join Date: 28-06-2003 Location: Wirral, NW England
My System: Various digiboxes, broken Nokia 9800S, numerous analogue boxes. My lovely little lappy, HP Omnibook 6100 | It's one of those tiny TVs with a telescopic aerial isn't it? You might be able to connect up proper coax lead by unscrewing the telescopic aerial and then, somehow, connecting just the centre wire from the coax. If that works then you've proved the principle and investigate the RF modulator route. | ||
| | #9 | |||
![]() So what I want to do is remove the RF element, so no AV-RF then RF-AV, just AV-AV, no need for a power source for the AV-RF adaptor, ontop of the power source needed for the TV and the AV device connected... ![]() So, I'd like to just hoik out the RF tuner, and go right to the AV inputs... ![]() (the bad dismemberment thing was a joke, I'm not that bad!!! I've had enough practise... | |||
| | #10 | ||
| Problem is that the tuner may go through another set of amplifying stages before they are correct for the audio and video levels. It might be worth looking for a schematic for the TV in serice manual (usually at your local library), or open the box up and look inside for test points, with an oscilloscope. | ||
| | #11 | |||
![]() As for an o-scope, not got one unfortunately, though I do know how to turn a TV into a rudimentary one, though that's more for audio effects than for actually probing things... | |||
| | #12 | ||
| Most of the libraries round here have a section for the manuals I used to use (television servicing). And Ebay 320389213761 | ||
| | #13 | |||
![]() Don't think I'd have the money to buy that collection though, I only have about £10 to my name at the moment... | |||
| | #14 | ||
| Specialist Contributor Join Date: 05-04-2005 Location: Midlands UK
My System: Skymaster DCI9900 + PC/twinhan combination. 80cm dish. GBPVR with 2 DTTV cards +hauppauge Media MVP | Just a few thoughts...... You could take a trip down to the reference library.....you may find collections of circuits there. Even if you can't find the exact model if you study a few you may spot trends which enable you to recognise where you'd need to input your signal to do what you want. The audio is probably easier to recognise but as sets have developed more is being done by fewer components so that may not be the case any longer. You may want to check out VCRs because they often had multiple inputs before it was common in TV and also they have nice low voltages to work with. Also, you need to remember that TV circuitry can be very cheap and nasty and live chassis used to be common practice - maybe less of a problem with portables | ||
| | #15 | ||
My System: Mostly gathering dust cos there's no room for dishes here... :( The Sleepy Hollow pollracle has spoken! | Completely forgot about this, but then I can't seem to find my handheld TV at the moment!! ![]() But thinking ahead, if I were to work out how to get it all worked out and working, I was thinking of how to connect up AV things to the handheld... ![]() Being a mono TV, it owuld be simple enough to get a 2-wire phono cable and a Stereo 3.5mm plug, wire it up with say audio on the middle ring and the video on the tip, with the ground being the outer ring, and do the same for a socket which I would fit inside the TV in place of the antenna, then solder it all into the TV, glue & screw, and try it out... ![]() And an application for it has come to mind already, a mini "spy" camera (wired or wireless), wouldn't be much of a picture, but would be great anyway... ![]() As for the little CRT portable, haven't had much thought on that, but, on the top, it has on the channel buttons the label "10/AV", which would lead me to assume that somewhere inside the TV there is circuitry for an AV input, just not utilised or lacking components, so all it would need is the necessary bits and maybe it'll just work, but I think that would need access to the TV repair bibles as mentioned!!! | ||
| | #16 | |||
It would help if you take few pictures, with emphasis on the connectors. | |||
| removing, tuner, whatsits |
