20uF Capacitor
For those who wish to discuss the more technical aspects of Satellite receivers and TVs. perhaps how to replace components, fault finding etc.
Old 04-07-2009   #1
mhku's Avatar
My System: DM7020S ~ DM500s ~ sg2100 ~ Gemini
If he were not a wizard, from head down to the root, you would have got to worry-your DB only boots
20uF Capacitor
Bit of a long shot but could I replace the 20 uF capacitor shown in the photo with a generic 20uF capacitor (the type sold on fleabay for a few quid)?
It's from a small Clarke compressor and searching google for "Geofarad 20uF" turns up nothing. I've emailed Clarke for a price for a replacement but would like a 2nd option if they take the mickey with the price.
20uF Capacitor-geofarad-jpg
You don't stop playing because you get old, you get old because you stop playing. Regras
Before posting in the Dreambox section please ensure you've read The Guide
Information is for educational purposes only
mhku is offline   Reply With Quote
Old 04-07-2009   #2
Llew's Avatar
My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes.
The one pictured on this site seems to be a good replacement regarding size -
_http://www.bltdirect.co.uk/cat548_1.htm
Best check the minimum AC voltage with them, I can't read what it's rated at.
Llew is online now   Reply With Quote
Old 05-07-2009   #3
Robbo's Avatar
Real name: Mark
Also from Maplin@ £6.13
_http://www.maplin.co.uk/module.aspx?moduleno=30309
or Ebay, less than a fiver delivered.
_http://shop.Ebay.co.uk/?_from=R40&_trksid=m38&_nkw=capacitor+20uF+motor
The Following User Says Thank You to Robbo For This Useful Post:
mhku (05-07-2009)
Old 05-07-2009   #4
Llew's Avatar
Just blown up the picture, looks like 240VAC
I should think ones on fleabay would suit if of the correct voltage rating.
Old 05-07-2009   #5
Llew's Avatar
Good find Robbo, looks the one to have.
Old 05-07-2009   #6
mhku's Avatar
Cheers guys
I forgot to subsribe to my own thread....
I'll check out those links now and wait for a price from Clarke.
p.s. google loves this site. This thread is already top 4 for 20uf motor capacitor!
20uf, capacitor
