soldering,of a broken tuner,lnb port,possible or not?
For those who wish to discuss the more technical aspects of Satellite receivers and TVs. perhaps how to replace components, fault finding etc.
Old 06-10-2009   #1
Turok's Avatar
My System: 1,25 Fibostop Jäger Smr 1224 & Smo 36 Dual Axsis Motor Dynasat F1 Monterey 140 Drembox 800 sky Pace HD Box Tagra 2,20 M Fullsize Dish Echostar 2,40m Mesh for cband!
Hello!
yesterday my,nokia dbox 2,fall down from the table,and now the antena inport is broken!
is it posible,to soldering a tuner,or not?
Turok is offline   Reply With Quote
Old 06-10-2009   #2
Toute Ronde Bon Oeuf
Tivù's Avatar
Real name: Gordon
Depends upon exactly where the break is - if it has just fractured the short stub from the female centre core to the tuner, I should have thought you could either resolder it in situ, or if it access is too confined perhaps you could try removing the tuner model and the socket to repair on the bench, before refitting it.
Can't really say without seeing it!
Tivù is offline   Reply With Quote
Old 06-10-2009   #3
My System: IP9000HD twin HD tuner operating > Triax TD110 Dish & 80cm FaVal Dish working in Tandem 60degEast to 60degWest Humax HDCI2000 operating > VboxII & 1.8 m Alcoa PF dish + Pauxis C-Band lnbf... Skystar2 /Twinhan SD /TS S2-3200 pci cards
Hi Turok ..
A Definative yes m8 ..
I do this sort of repair regularly...its in my job description..
Broken aerial sockets on terrestrial TV tuners ..Cable boxes...and Satellite boxes..
The fault usually has occurred when the owner removes the stb from their system ..without removing the antenna cord first ..
..It snatches and the connector seperates from the tuner.
The material of the tuner is basically tin coated metal ...and resolders easily with a hot enough Iron..
Just make sure to resolder the centre pin first if possible ..this gives an anchor for the broken socket and holds it in place whilst you flow solder around the outer connection.
rgds
VS
Vipersan is offline   Reply With Quote
broken, lnb, port, soldering, tuner
