To Barrel or Not to Barrel, that is the question
Thread Tools Display Modes
Old 03-02-2005   #1
Anatolia correspondent
My System: GoldMaster 7400 CIM 2MB with Kaon board 12.03.a5. Sunny AT-8012D with Kaon board 16.C0.A1 Two 80cm offset dishes. One 120 cm table top offset dısh. Double output LNBs from Kipa supermarket.
Question To Barrel or Not to Barrel, that is the question
What's the best way of joining two lengths of RG6 coax?
I could terminate each piece with an f connector then connect them together with a barrel connector. But in effect this is two connections. Is there a better way......?
Artist 2004 is offline   Reply With Quote
Old 03-02-2005   #2
Mod and septic resident
Channel Hopper's Avatar
What type of signal are you pushing down it ?
__________________
Old 03-02-2005   #3
Good question, it's between a DiSEqC and a satellite receiver.
Old 03-02-2005   #4
The loss would be in the region of 0.6 to about 1dB for a decent matched set of connectors, and so unless you are near the end of the sensitivity of the receivers tuner, you should not get any problems. Make sure however the electrical contact of outer and inner are good, preferably by scraping any crud off the inner connector circumference.
Needless to say it shold all be done in dry conditions and external work to be waterproofed after.
__________________
Old 11-02-2005   #5
Thanks C.H.
Forum Jump
Similar Threads
MM software version question geokar Magic Module 3 27-02-2004 12:51 PM
"F" Plugs (Very sad question....) j.m. B Sky B Digital and 28.2 East General 19 23-02-2004 10:53 AM
Forgive the stupid question, but . . . mulls74 Digital systems 4 11-11-2003 11:08 PM
Question Mark Fardelli Sky (UK) Platform Astra 28.2E: Astra 2D Fringe reception & Tech 1 18-08-2003 11:00 AM
Small Question about recieiver fruitbat Digital systems 3 10-07-2003 08:10 PM
All views and information expressed in users' communications and profiles represent the opinions of the users concerned and do not represent the views of Satellites.co.uk. All images and news content are believed to be in the public domain, except where otherwise stated. Forum software by vBulletin® Version 3.8.0
