Frozen Diseqc motor | |
| Specialist Contributor Join Date: 29-08-2004 Location: dublin,ireland
My System: Dreambox 800 HD PVR Gibertini 85cm dish superjack 120 motor........ linksys access point connected to dreambox.. |
Hi guys... Hope this is the right forum for this post..I bought a Superjack DG120 diseqc motor late last year, I hadn't used until this week when I went to do a test connected to the reciever before I installed it..the motor moved a few degrees and froze and now I cant move it back it looks like no power is getting to the motor..any ideas...please | ||
| | #2 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | Does that model have controls on the motor as well? If it has, have you tried using them?
__________________ | |||
My System: Dreambox 800 HD PVR Gibertini 85cm dish superjack 120 motor........ linksys access point connected to dreambox.. | Hi rolfw.. Yes the motor has a left and right manual switch but I'v tried these as well and no joy..any ideas..anybody Cheers | ||
| | #4 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | Well if there is power going to it and the manual switches won't work, it will be a case of return to supplier.
| | #5 | ||
My System: Dreambox 800 HD PVR Gibertini 85cm dish superjack 120 motor........ linksys access point connected to dreambox.. | Thanks rolfw for the reply.. I sent off a mail to the supplier in Germany but got no reply so out of frustration I brought the motor into an electronics expert in work who is looking at it as I type..so I'm sure this nulls my waranty....hard lesson learned if it does!! Cheers anyway | ||
Similar Threads | ||||
| Best DiSEqC Motor ? | seret | DISH SETUP: Single sat, Multi-Sat & Motorised systems | 38 | 06-09-2005 12:38 PM |
| Help needed with My Theatre & DiSEqC switch please | davie | DISH SETUP: Single sat, Multi-Sat & Motorised systems | 9 | 19-03-2004 07:34 PM |
| Antenna Feed switches: 12V & Diseqc | jeallen01 | DISH SETUP: Single sat, Multi-Sat & Motorised systems | 3 | 16-02-2004 11:56 AM |
| is this a diseqc problem | doggy | DISH SETUP: Single sat, Multi-Sat & Motorised systems | 14 | 05-09-2003 02:44 AM |
| diseqc motor & Echostar problems - HELP! | css_jay99 | DISH SETUP: Single sat, Multi-Sat & Motorised systems | 0 | 25-06-2003 02:35 AM |
