IR full power off control
Thread Tools Display Modes
Old 21-02-2005   #1
More dishes than Sense.
closetosoton's Avatar
My System: 7 dishes. 9 LNBs. And a whole load of receivers + One broken TV.
hi soldering iron fans.
i have an old panasonic TU-SD200 analogue receiver which is still in use on 5W for ye olde analogue french channels. i use it once in a blue moon, and mostly it sits there drawing unecessary power getting fairly hot (i've already repalced the PSU capacitors once to keep it alive), so hot, all its rubber feet have melted and made a sticky mess. when powered off i'd like the whole PSU stage to be put to sleep, and hence LNB off too (as it is its on 100% of the time even in standby). i plan to add a secondary lower power psu just for turn on/turn off via IR and some relay combination. i haven't set to search the web in its deepest darkest parts yet - does anyone know of a simple kit that can power on/off devices via IR, which I can maybe butcher and incorporate into the receiver?
cheers - cts
closetosoton is offline   Reply With Quote
Old 21-02-2005   #2
Super Minty Mod
PoloMint's Avatar
My System: 1200cc with 100,000,000,000 neurons and 100,000,000,000,000 connections
I've seen IR controlled socket adapters before. They look like the timers people get that plug into sockets, and lights plug into them (to put lights on and off when people go on holiday) except instead of having a timer they have an IR sensor and a remote control. Perhaps that could be taken to bits and the IR and switching part built into your receiver?
__________________
'All you need is duck tape and WD40; if it moves and it shouldn't, use duck tape - if it should move and it doesn't, use WD40'
PoloMint is offline   Reply With Quote
Old 21-02-2005   #3
Llew's Avatar
My System: Triple Dragon with HDD/USB stick, Humax HDCI2000, Echostar AD3000ip & SR8700, Fortecstar 5100CIUltra, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. Diablo/Mrev Cams
Hi cts
Maplin do an IR TX/RX that might fit the bill (providing you have room in your receiver).
N95AU - IR TX (£9.99)
N96AU - IR RX (£9.99)
The relay switches only up to 24V so maybe you could add a 240V relay from its contacts.
This could switch the PS off, but of course you will need to maintain a supply to the IR receiver - a simple 240 - 12V (or whatever powers the IR RX) converter wired to the mains in socket.
Llew is offline   Reply With Quote
Old 21-02-2005   #4
sounds good, somebody pointed me at a IR remote controlled power socket, as in Polomint's suggestion - this was from Lidl at £15, however that was purcahsed before xmas and I suspect stocks have long dried out. cheers. cts
Old 21-02-2005   #5
Super Minty Mod
PoloMint's Avatar
There are a couple on Ebay at the moment, but they are not cheap. They also seem to be RF rather than IR, but I doubt that matters.
http://cgi.ebay.co.uk/ws/eBayISAPI.d...753427038&rd=1
http://cgi.ebay.co.uk/ws/eBayISAPI.d...957873195&rd=1
__________________
Old 22-02-2005   #6
Thanks for the links, but I do need IR, since I have a whizzy programmable Sony IR remote which I use to control my 'life' I don't really want an RF based system....
If I could get an equivalent IR system for about £10, that'd do the trick.... I don't need 3 sockets of course, then again the attraction of making my lights remotely controlled is now begining to appeal!
Cheers.
CTS
Forum Jump
Similar Threads
Signals, noise, digital errors ... all that stuff. spiney Members' input on FAQ and How To's 0 02-04-2006 04:41 PM
ZENEGA CD -1002S software needed for Dish TV India- Part II Tom Robert Indian Subcontinent General Section 467 02-08-2005 12:55 PM
Freeview owners rule out full return path for service net1 Terrestrial Television, Digital and Analogue 3 18-12-2004 07:09 PM
News Corp takes full control of Sky Italia net1 Daily Satellite and Broadcast industry News 0 29-09-2004 07:03 PM
Murdoch to take full control of Sky Italia net1 Daily Satellite and Broadcast industry News 0 16-09-2004 06:32 PM
