Help please fixing Panasonic VCR
Thread Tools Display Modes
Old 15-05-2005   #1
Can anyone advise as to whether or not it is worth trying to repair (or have repaired) a Panasonic NV-FJ630B-S VCR. The problem is that there is no UHF output. Works only through scart. Any suggestions please on whether a repair is worth considering.
cableman is offline   Reply With Quote
Old 16-05-2005   #2
spiney's Avatar
My System: Pace 2200 Sky digibox with ftv card, Comag SL65 FTA sat receiver, 40cm Sky minidish, Setpal terrestrial receiver (for free uk tv only!).
more info needed.
when you say no uhf, do you mean loopthrough has failed, that you can no longer plug aerial into vcr, then vcr into tv? if that still working, then rf amp ok, so probably modulator is as well.
Sure it's not just your tv lost the channel? try playing tape and scanning all uhf channels on tv.
is ouput channel a screw on back (v old!)? Or set by software, if so has it changed, or software glitched? try unplugging vcr from mains, waiting 1 min, then resetting everything.
if modulator gone then, yes you can probably get spare one, soldering needed, so maybe new vcr better, they're very cheap.
hope helpful.
spiney is offline   Reply With Quote
Old 16-05-2005   #3
Thanks Spiney for your reply. The situation is that although I can loop-through to TV and receive my TV channels on the TV, when I switch on the video there is no change and I can only tune in the TV to the channels as before (no video channel, just as If the VCR were in standby). No RF channel adjust on back of machine. Equally, with a tape playing I can not find this when attempting to tune TV. But you are right that the machines are so cheap (dinosaus?) nowadays.
Old 16-05-2005   #4
rolfw's Avatar
Some videos have an rf on/off switch on the back and some have it in internal menus, has the rf out ever worked?
My HD600B has it between the scart sockets, it is also the test signal switch.
__________________
Rolf
Donate
Old 17-05-2005   #5
spiney's Avatar
if all that fails, it would mean taking "lid" off modulator top and sticking 'scope probe in to see if oscillator's working .......
Old 17-05-2005   #6
Llew's Avatar
My System: Triple Dragon with HDD/USB stick, Humax HDCI2000, Echostar AD3000ip & SR8700, Fortecstar 5100CIUltra, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. Diablo/Mrev Cams
... or get an outboard video modulator (30 quid from Maplin's) if you can't bear to dump your VCR.
Spiney, with the oscillator working at around 600MHz, you're going to need a pretty good 'scope to see the trace...
Llew is offline   Reply With Quote
Old 18-05-2005   #7
spiney's Avatar
rf diode probe.
Old 18-05-2005   #8
Llew's Avatar
Good point. Although I prefer my spectrum analyser.
Old 18-05-2005   #9
spiney's Avatar
granted, that's much better, if you've got one.
Forum Jump
Similar Threads
ASTRA 2D BBC & ITV RECEPTION Expat Sky (UK) Platform Astra 28.2E: Astra 2D Fringe reception & Tech 574 4 Weeks Ago 09:06 PM
Comparison between Grundig GDS3000 and Panasonic DSB30 Andrew Steel Sky (UK) Platform Astra 28.2E: Astra 2D Fringe reception & Tech 6 05-05-2004 10:54 PM
Panasonic to close UK production of TVs and STBs net1 Daily Satellite and Broadcast industry News 0 23-01-2004 08:37 PM
Panasonic DU-TSB30 skipzoid Magic Module 5 13-01-2004 03:14 AM
Grunding versus panasonic bunchy62 Sky (UK) Platform Astra 28.2E: Astra 2D Fringe reception & Tech 21 03-09-2003 07:46 PM
