Schematic For Echostar AD3000ip Power SupplyFor those who wish to discuss the more technical aspects of Satellite receivers and TVs. perhaps how to replace components, fault finding etc. | |
| | #101 | ||
| Member Join Date: 24-12-2008 Location: Germany
My System: AD3000IP, 2* IPBox 250S PVR, Kathrein 90 dish with 2*Quattro LNBs, dBox1, a couple of PC TV cards | This was a good one (the link) and a real good one (to use google translation). Looks as if google still needs some more investment into it's translation routines, since the result was really amusing. I had a closer look using a magnifying glass and, well the hotspot turned out to be more or less a desoldering-spot. One end of the resistor seems to have totally lost contact, and when I watch Llew's schematics this surely blew up either diodes or ICs if not both. I assume so since correcting this issue didn't change anything. Thus, thanks for the link, hopefully this guy does respond to my email. | ||
| | #102 | ||
| Member Join Date: 14-10-2007 Location: NL
My System: ad-300IP | Hi Justone Google translate can be very amusing indeed, but i find it very helpful in understanding at least something of a language i don't have any idea about. I live in the Netherlands so if i can be of any help, let me know. Vlammie | ||
| | #103 | |||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed |
Voltages look OK (when it's stable), I suspect an intermittent contact somewhere. Tapping or prodding components gently with an insulated probe (plastic pen etc.) may find the culprit. Using an aerosol freezer or warming up components when the fault occurs can often isolate faults too. Llew | |||
| | #104 | ||
My System: AD3000IP, 2* IPBox 250S PVR, Kathrein 90 dish with 2*Quattro LNBs, dBox1, a couple of PC TV cards | Thanks Llew & Vlammie ... bought the one Vlammie pointed at, and it arrived today, and works like a charm. (wonder how one managed to get next to no hotspot, looks as if being really rarely used). And it was really cheap keepin' in mind that I would likely have payed much more for 3-4 ICs on their own. And the good thing, I could likely measure some voltages at differnt points to see if I find vital differences between the damaged and the working one, and see if I could locate the issue using Llew's nice schematics. | ||
| | #105 | ||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | Good to know that there's a source for these PSU's, Echostar spares don't usually appear on the market. Might get one myself as a spare before they dry up. Yes, a voltage comparison might be worth doing. Glad that you are up and running. Llew | ||
| | #107 | ||
| Member Join Date: 14-10-2004
| Hi Folks, I have also some psp problems with my AD-3000IP and read all your recommendations. As a contribution i'm posting 2 original schematics from this receiver ![]() Best Regards Thomas from Brazil | ||
| The Following 3 Users Say Thank You to toz99 For This Useful Post: |
| | #108 | ||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | Excellent toz99. I shall now check any mistakes in my schematic ![]() Thanks Llew | ||
| | #109 | |||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | There's little protection for an LNB or cable short, no fuse. Usually one of the H/V switching transistors gives up the ghost if the short is prolonged. Llew | |||
| | #111 | ||
| Member Join Date: 09-12-2007 Location: UK
My System: Dual xeon 2.2 Skystar2 Amstrad Digibox Silvercrest SE65 E1 Nokia 9800 Echostar AD3000 Echostar LT8700 (Retired) | Hi - my AD3000 seems to be fading.....Its a great machine but recently has lost channels still available on my other box. A tuner fault maybe? Anyone got any ideas as to whether this can be repaired? | ||
| | #112 | ||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | Perhaps your transponder database is full. Try deleting some TP's that you don't use and rescan those you need. | ||
| | #113 | ||
| A full reset is probably in order, and just scan in the FTA channels on the more popular satellites. Anyone with a motorised dish of 50cms or more with a 3000/3600 could well be in jeopardy now there are so many transponders out there. | ||
| There is a very fine line between "hobby" and "mental illness" | |||
| | #114 | ||
My System: Dual xeon 2.2 Skystar2 Amstrad Digibox Silvercrest SE65 E1 Nokia 9800 Echostar AD3000 Echostar LT8700 (Retired) | Hi Thanks for the replies. To clarify, the channel list is not full. It just won't find previously scanned channels, reporting 'no signal'. Its as though the signal has become very weak but this is not the case as my other box works fine. If the tuner module is suspect, can it be repaired/replaced?? Cheers, Sixoence | ||
| ad3000ip, echostar, power, schematic, supply |
Similar Threads | ||||
| problem with power supply of galaxis | Soledad Torres | Digital systems | 1 | 10-09-2005 11:45 AM |
| laptop power supply | skylark | Computer Discussion | 4 | 17-05-2005 11:06 PM |
| Cryptik power supply voltage and polarity? | BGonaSTICK | Cards & Programmers General | 2 | 27-03-2005 12:22 AM |
| Humax Power supply | Shogun | DISH SETUP: Single sat, Multi-Sat & Motorised systems | 0 | 11-04-2004 10:14 AM |
| Power supply problem in Humax 5350 | jobbe | Digital systems | 1 | 08-12-2003 12:48 AM |
