Can sky freesat card be used in Diablo cam? | |
| Member Join Date: 05-12-2006 Location: Finland
My System: Canaldigital CDC-7000 st |
| | #2 | |||
| Member Join Date: 07-11-2005 Location: Glasgow
My System: Passion HD Diablo CAM Sky+ HD Sky Star 2 PCI | Edit - Just to clarify I am referring to sky Uk. Last edited by Ratchet; 05-10-2007 at 12:57 PM Reason: Clarification | |||
| Member Join Date: 16-10-2007 Location: UK
My System: TM ci +.....Diablo | As Far as I know, there is only the t/rex cam along with a couple of programmable linux boxes, possibly a cc cam that will work if you wish to use your valid paid subscription card in another box. ![]() The Diablo cam regardless of version software is not capable of working with such cards. | ||
| | #4 | |||
![]() Let me reiterate again, I have a Diablo CAM and 2 sky cards both of which work perfectly well on Stealth levels up to 2.15. I have already reported on the Stealth 2.16 thread that sky UK support is lost at that level. | |||
| The Following User Says Thank You to Ratchet For This Useful Post: | Robbo (17-10-2007) |
| | #5 | ||
My System: TM ci +.....Diablo | I do apologise there Ratchet, I jumped the gun a bit (perhaps a little wishful thinking on my behalf) and was certainly not trying to undermine your post, I bit not read the first post thoroughly in respect to the “FREE VIEW” line, yes it is possible to use the Diablo for free view plus the basic family package, problems start when you wish to watch the sports/ movies, I know of many that have gone out and spent their hard earned pennies on the t-rex even though they have already bought the Diablo so to be able to use their pvr boxes to record the premium package channels and over come the sky + issues. I have so far been unable to overcome the original serial number by which the card is married to the original box it was activated in, I do not know of a way to input the box serial in the Diablo software like you can on the Dragon/t-rex, perhaps you may be able to help on this one Ratchet if you have had any success, also thanks for the heads up on the 2.16 version not working on the nds. Again sorry for the out burst I stand corrected. | ||
| | #6 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | There appear to be some advances being made on this front, see this thread, again though, whether they have solved the keep alive problem, we are yet to find out and it doesn't say whether the CAM which is mentioned in the thread lower down is capable of viewing the premium channels.
__________________ | |||
| | #7 | |||
I hope the 2.16 problem is fixed on the next release. Don't want to see sky UK support wither away with subsequent releases. I've read elsewhere that 2.16 supports the latest sky Italia cards, hopefully the Stealth team can find a way of supporting both in the same level. Last edited by Ratchet; 18-10-2007 at 12:10 PM | |||
