Help updating a Diablo with Cas 2 programmer.
Satellite TV support fourm for X-CAM, Ultra CAM, Dragon CAM, Diablo, T Rex.
Old 30-10-2007   #1
My System: hi all
hi all
i have diablo cam with original version"not sealth", and cas interface 2,
probleme , when i insert cam in the cas2, diablo can't be connect, i dont know why?
shanboy is offline   Reply With Quote
Old 30-10-2007   #2
There have been a few problems reported with the Diablo cam and Cas 2.
Have you tried using the latest CIS 8.3 software, available from duolabs?
If that fails try using CIS 7.9C, to use this you will have to alter the date on your computer, try changing the date to 2006.
Then start up your CIS software and click on the Cam Module tab, and the Diablo Cam icon.
This will open the Diablo Cam software, click on Cam Disk Funtions and Format.
Once the cam is formatted click on the Upgrade Cam tab, and click on the small icon, with 3 dots on it, at the end of the File Name bar, and navigate to stealth218.dup.
The traffic light symbol on Start Update, should now be green, click on it and the Cam should update.
After it is updated, download the latest Diablo keys.bin file, place it on your desktop, click on the Cam File System tab, and Connect.
Locate the new keys.bin file, in the bottom left pane, and overwrite the old one by clicking on the green arrow pointing right.
Exit the programme and insert the cam in your receiver.
Now you need to set the configuration settings, enter the cams menu and Configuration.
Ensure Emulators is set to ON.
Emulators Priority is 1 Emu 2, Cards,.
Now you should be able to view the channels.
Mickha is offline   Reply With Quote
Old 30-10-2007   #3
My System: hi all
thank you Mr.Mickha
Old 31-10-2007   #4
My System: hi all
i was do all etape
but in the end of download cas2 show " error updating file" and the cam show 218 but not work
Old 31-10-2007   #5
Please stop posting the same question in different threads, I have answered your other thread.
cas, diablo, programmer, updating
