Diablo CAM and Canal Digitaal
Thread Tools Display Modes
Old 09-02-2008   #1
My System: Motorized dish | Topfield TF5000CI | Diablo CAM | Canal Digitaal smart card | CAS 3+ Interface
Hi all,
I have a Diablo CAM with a Canal Digitaal official smart card which I activated a few weeks ago. If I try to watch a channel from the package I have subscribed for I see nothing, as with the CAM at all.
Do I have to do anything with the Diablo CAM to be able to see the crypted channels?
If I check the details of the smart card via the receiver menu I see that the encryption type is unknown... Should'nt the receiver recognize it as Mediagard?
Thanks to all!
roshii is offline   Reply With Quote
Old 09-02-2008   #2
I know this might sound a stupid question but have you got the card inserted the correct way up?
Have you tried going into the Cams menu, configuration and altering the CAID and other settings?
If you have already tried this and it doesn't work please post back and I'll search if anyone has an official Canal Digitaal official smart card working in a Diablo cam.
__________________
Mickha is offline   Reply With Quote
The Following User Says Thank You to Mickha For This Useful Post:
roshii (10-02-2008)
Old 10-02-2008   #3
Thanks Mickha
I have tried to re-insert the card and so on but it does not help...
I have also tried to change some CAM settings but I could not find what you advice. The only options available are: Auto PMT & Providers but I do not know what to put there...
The Diablo CAM has a Boot version 1.41
Thanks for anybody who could help further.
ps: would it help to purchase a CAS 3 programmer?
Old 11-02-2008   #4
I've been offline, thanks to my ISP, for 12 hours.
If you go into the configuration menu, and click on CAID's File, you will see the option to select different CAIDS including German, Spanish etc.
Hopefully one of these options might work with your card.
Have you got the card inserted with the chip facing up?
You could also try a search of the internet to see if anyone has this card working with this cam, and what file and settings they are using.
__________________
roshii (14-02-2008)
Old 14-02-2008   #5
Sorry Mickha for not replying earlier...
The card is recognize in the configuration menu of the receiver, it shows a hex key and says the coding system is unknown; therefore i assume the card is inserted correctly...
Unfortunately, I could not see any option to select CAIDS in the configuration menu of the receiver. What is CAIDS by the way?
I could not find anything on the internet either.
Could it be the boot version of the Diablo CAM that is not up to date?
I see that my boot version is 1.41
I have also purchased a CAS 3+ interface as i thought it might help...
While i was checking the settings of the CAM i stepped on "Providers list" and i was wondering if i should not add Canal Digitaal here... But then came a question, what is the code corresponding to Canal Digitaal?
Looking forward to any tip Regards
Old 14-02-2008   #6
If you enter the Diablo Cams menu, then enter configuration, highlight CAIDS and Enter you will see a lot of different choices.
Which Stealth file do you have loaded on your Diablo Cam?
The latest is Stealth 238.
__________________
roshii (15-02-2008)
Old 15-02-2008   #7
I will try to go into CAIDS right after work! But I am doubting... Anyhow, I'll see this evening...
I have not loaded any Stealth file yet as I do not know if it would help me... Further more the only one I have found is 1.78... Any tip on where to find 2.38?
Old 15-02-2008   #8
Your cam requires a Stealth file to work as this is the firmware for it.
If you have a search through the forums links section:
http://www.satellites.co.uk/satellit...lys-big-links/
you will find a lot of useful links from other members, alternatively type stealth238 into google you will find some links.
__________________
roshii (16-02-2008)
Old 16-02-2008   #9
Yiiiiipie!!
It works! I have uploaded Stealth 2.38 and with this I could indeed alter the CAIDS. I did put it on "Others" and the card did get activated
Thanks for your support and patience Mickha!
I will now investigate the possibilities of the Diablo CAM
Old 16-02-2008   #10
Packages currently open with the Diablo Cam are:
Premiere 19.2E
TPS, SRG & Polsat 13E
Digi TV 1W
Also open, with the latest keys.bin file, are the MCT/Redlight porn channels on 13E.
__________________
roshii (17-02-2008)
Old 03-05-2008   #11
My System: tm dh 6800+250 hdd usb,tevion hdd/dvd recorder,tevion upscaler hdmi dvd player,philips 42 plasma hd,.beheringer psudo surround thru hi fi ,..
canal digital is conax if its from w 1 thor,..the diablo cam is an official conax cam in its original state [new] but if you have loaded any patch on it,eg ,darkman etc,etc,.it wont recognise the official conax card,.then you will have to contact duolabs and ask them for advice,...good luck,..let us know how you get on!,..teddie,..
teddie is offline   Reply With Quote
Old 05-05-2008   #12
Hoi Teddie,
I have a smart card for Canal Digitaal on Astra 23.5°E which works just nice with the latest Stealth. The CAM also open TPS without any problems. I have no complain to make.
Greetings
Old 27-06-2008   #13
My System: technomate 1500CI Triax 90cm motorised dish
is there a section for people who are new to cams, how do i go about getting past these encrypted channels, if i buy the diablo cam what else do i need ?
graham is offline   Reply With Quote
Old 27-06-2008   #14
Amo Amas Amant Admin
Topper's Avatar
Well
It is not something that has a definitive how to guide as the scene is changing constantly day by day. You have got to decide what you want to watch and which satellite it is on then see if it is possible. There are many encryption systems and more than one way of cheating those systems either using cams, emulators or patched firmware. A good read here will enlighten you further.
__________________
Formerly toppervte33h
Show Your Support
by clicking the button
Thank you.
Freddie Flintoff is back
canal digitaal, diablo cam, encryption, mediagard
Forum Jump
All views and information expressed in users' communications and profiles represent the opinions of the users concerned and do not represent the views of Satellites.co.uk. All images and news content are believed to be in the public domain, except where otherwise stated. Forum software by vBulletin® Version 3.8.0
