T-Rex, Sly and Dvbviewer - need help pleaseSatellite TV support fourm for X-CAM, Ultra CAM, Dragon CAM, Diablo, T Rex. | |
| Member Join Date: 16-02-2008 Location: D
My System: FireDTV (DVB-s CI) DVB Viewer T-Rex Supermodul 4.6 |
Dear all! I´m on the internet for hours now but nothing works... I have got a T-Rex Supermodule, a Phoenix Infinity Umlimited USB Programmer, a T-Rex Loader Card , a Fun7 Card, a FireDTV (Dvb-s) with CI and the DVBViewer and all I want is to watch Sly (Five and Channel 4) with my FTV Card on my PC... I understood, that it is necessay to change the firmware on the Supermodule. I tried to write Predasaurus on both cards with my phoenix programmer. What next? I started DVBViewer, chose View and CAM Menu, but the menu just tells me "no Smartcard inserted" or "Smarcard error (no ATR)". Can somebody help me??? I read that I have to write the cards in phoenix mode 6Mhz. Where do I find this setup in the phoenix software? Yes, I chose the right card in the phoenix software and also put the cards in the right way into programmer and cam. Excuse my bad English, please. | ||
| Super Moderator Join Date: 10-12-2004
![]() | Hi Klaus1001, welcome to the forum. In future please start a new thread, in the appropriate section, when asking new questions as isolated posts in old threads tend to get overlooked. With your programmer you do not need to go into Phoenix mode to program either card. You can use either the Fun 7 or T-Rex loader card to update your cam. First ensure you have the latest software for your programmer, you can do this by starting up your programmers software, clicking Help, About and check for updates. To program the Fun 7 card: Start up your software, insert your Fun 7, chip facing down, and from the drop down box choose DragonLoaderCard (AVR). Leave the built in loader. Click on the folder icon next to Ext EEProm and load predasaur225.dra. Click Write. Once complete load your T-Rex Cam. Tune your receiver to a FTA channel, like BBC World. Turn off your receiver. Insert your loader card into your T-Rex cam, chip facing up, and if not already insert your cam into the receiver. Switch on your receiver. Navigate to the cams menu and select load cam. Once complete you will see a message asking you to remove the card, and switch off the receiver. Do so. Turn on your receiver and you should have Predasaur 225 loaded on your cam. The directions will be slightly different as you are using a PC card and CI but should be easy to do. To program the T-Rex loader card just select DragonLoaderCard (PIC) and follow the same instructions. To use your S*y card simply insert the card chip facing upwards and it should work. | ||
| dvbviewer, sly, trex |
