Predator 3.32 and original subscription cardSatellite TV support fourm for X-CAM, Ultra CAM, Dragon CAM, Diablo, T Rex. | |
| Member Join Date: 12-07-2007 Location: H
My System: P4 1.7 GHz 1.5 GB Ram 80 GB HDD |
Hi Everyone, I have dragon cam 4.1 with predator 3.32 loaded and a legal irdeto v5 subscription card. When I go to the menu and check SmartCard, the cam recognizes my smartcard and and says Decoding OK. My problem though is I have no picture even when I keep the decoder on for 30 to 1 hour no joy; it keeps on telling me decoding ok but still no image. Recently, our Irdeto Satellite provider introduced smartcard & decoder marriage (pairing). I wonder whether that is why I'm having trouble getting picture even tough when I use my Irdeto Cam in my Technisat decoder (with the latest firmware from the manufacturer) I have picture, which goes off from time to time forcing me to reset the cam or restart the decoder. My question: is it possible to rectify the behavior of the predator so that I can get picture or is there a way to input the decoder serial number for Irdeto in Predator? In the debug menu there are only N*gra and ND* box key. PS: I should mention that only Predator 3.32 is decoding all other versions up to 3.65 do not decode with the provider's smart card. Thanks in advance for your help. | ||
| Super Moderator Join Date: 10-12-2004
![]() | Which Irdeto encrypted provider is it? It might be as simple as adding the correct CAID to the later Predator files. This can be done very easily using Prededit 1.4, which you can find here: Prededit 1.4 If you download and run this you can add the required CAID to the later Predator 365 file. Click on the folder icon at the end of the Open File address bar. Navigate to predator 365, I usually save the file on my desktop to make it easier to find. Once Opened click on the CAID tab. You can now see the CAID's loaded and those you can add. Take out some of the CAID's you don't use and add the Irdeto ones you require, by highlighting them and using the arrow symbols. Once complete click Save CAID's in Dra and load your newly modified file onto your cam. You can also copy the CAID's from your old Predator 332 file using this utility. Open Predator 365, click on the tools tab, and Copy all data from another DRA. Click on the folder icon at the end of the Source DRA file address bar and load predator 332. Untick Provider and DCW/BISS but leave CAIDS ticked. Click copy and save data and load your newly amended predator 365. Please post back if you have any problems. | ||
| | #4 | |||
| | #5 | |||
| Member Join Date: 19-11-2008 Location: South Africa
My System: Dreambox 500 S, Eutelsat W3A and Intelsat 7 & 10, Sirius 4.8E, Telstar 12 | Hello! I am having the same problem, I use CCcam, Any Solutions out there? Thanks Mashster
| 332, card, original, predator, subscription |
