diablo lite | |
| Member Join Date: 26-09-2007 Location: sheffield england
My System: diablo light cam cas3+ interface fortec star 5100 ultra astra dish |
i have a diablo lite cam with a monoblock lnb so i can view astra and hotbird the latest diablo update keys. it loads quite a few channels, i have been told to try mct , sexview and the redlight mix if i want to view pron but when i try i get the scrambled channel message none of these work i have put it on france 4 until it clears then switched but still nothing, am i doing anything wrong any help would be very welcome thanks | ||
| Super Moderator Join Date: 10-12-2004
![]() | Sexview was available on the Diablo light, but is not at the moment. MCT was open with the T-Rex 4.6, but very briefly, and is again no longer viewable. TPS, shows porn on the Multivision channels after 11 PM, and there are porn channels on Astra 19E, part of the Premiere package, both these are viewable with the Diablo light. If you can get 1W you can also view the Digi TV package which I think has a Spice porn channel. You can get a full list of erotic channels on Premiere here: _http://www.lyngsat.com/packages/premiere.html | ||
My System: diablo light cam cas3+ interface fortec star 5100 ultra astra dish | thanks for the reply, but when i get the latest update this is whats included and it mentions the above pron stations Fausto -> Diablo_Idents_List.txt XML Source File -> KEYS.XML Modified by -> File Update -> 09/05/2008 ======================================== Coding System: Biss ======================================== 000001-DISTRIVISI (030.0 W) 000001-KBS World (068.5 E) 000001-KD Romania (062.0 E) 000001-N GEO DEUT (019.2 E) 000001-NBA TV (027.5 W) 000001-NGEO IBERI (016.0 E) 000001-NTV (042.0 E) 000001-TV8 (042.0 E) 000002-NGEO Turk (016.0 E) 000003-TVE LPC (030.0 W) 000004-NBA TV (042.0 E) 000004-TVE L2C (030.0 W) 000005-MEGASPORT (004.0 W) 000006-M1 INTER (004.0 W) 000007-1+1 (004.0 W) 000010-Canal 4 (030.0 W) 000014-LDTV (030.0 W) 000016-AXN (030.0 W) 000063-MGM (010.0 E) 000064-Aljazeera (016.0 E) 000065-NTS (075.0 E) 000067-RUSTAVI 2 (042.0 E) 000069-Fox Life F (005.0 W) 00025B-BOUCHAOUI (005.0 W) 00025C-ENTV (005.0 W) 0007DA-DISC CH ME (010.0 E) 0007DC-RTRS (011.0 W) 0007DD-ATVBL (011.0 W) 0017DE-TET (005.0 E) 002135-RAI AFRICA (013.0 E) 00377D-Fox TV Ser (012.5 W) Ident(s): 31 ======================================== Coding System: Cryptoworks ======================================== 000004-DMC/UPC (015.0 W) 000004-ORF (019.2 E) 000020-Kingstone (005.0 E) 000030-Kingstone (005.0 E) 00005C-Turner (013.0 E) 000060-Turner (013.0 E) 0000A0-British Telecom (013.0 E) Ident(s): 7 ======================================== Coding System: Irdeto ======================================== 000000-ORF (019.2 E) Ident(s): 1 ======================================== Coding System: zOthers ======================================== 000000-ART (007.0 W) 000000-SexView (013.0 E) 000000-FreeX Tv (013.0 E) 000000-La7 CartaPiu (012.5 W) 000001-ShowTime Id01 (007.0 W) 000002-ShowTime Id02 (007.0 W) 000501-Premiere World (019.2 E) 000501-Premiere World (019.2 E) 000503-Premiere Star (019.2 E) 000505-Premiere Alp. TVX (019.2 E) 001101-Kabel Deutchland (019.2 E) 003101-ORF (019.2 E) Ident(s): 12 ======================================== Coding System: Irdeto 2 ======================================== 000000-MCT (013.0 E) Ident(s): 1 ======================================== Coding System: Nagra ======================================== 002201-Multicanal (030.0 W) 002301-Multicanal (030.0 W) 002C01-SABC (068.5 E) 002D01-SABC (068.5 E) 007401-DigiFun Club - 42E (042.0 E) 007501-DigiFun Club - 42E (042.0 E) 00A401-Antenna Hungaria (004.0 W) 00A501-Antenna Hungaria (004.0 W) 004F01-Dream TV Ident(s): 9 ======================================== Coding System: Nagra 2 ======================================== 000501-Premiere (019.2 E) 000505-Premiere Tvx (019.2 E) 001101-Kabel Deutschland (023.5 E) 001102-Kabel Deutschland (023.5 E) 002111-DigiTV (001.0 W) 007101-Polsat (013.0 E) 00C102-Tv Globo (13°E) 000101-Dish Network Ident(s): 8 ======================================== Coding System: Seca ======================================== 00002A-MediaTech (S1) (004.0 W) 000030-RAI (S1) (013.0 E) 000065-Cyfra (S2) (013.0 E) 00006A-C+ NL (S2) (019.2 E) 00006C-Canal Digitaal (NL) (019.2 E) 000080-CSN (S2) (019.2 E) 000081-C+ France (S2) (019.2 E) 000084-Numericable (S2) (013.0 E) 000085-FTC (S2) (019.2 E) 000086-Pro Tv (S2) (019.2 E) 0002E2-RAI (S2) (013.0 E) Ident(s): 11 ======================================== Coding System: Viaccess ======================================== 007C00-TPS France (013.0 E) 00A000-BBC Prime (013.0 E) 021500-MCT DCW (013.0 E) 022C00-RTVI Ident(s): 4 ________________________________________ Idents in file: 84 ________________________________________ kargo.25 does this mean that not all are available, thanks and sorry to be a pest | ||
![]() | Most of them probably were available at one time or other, without going through the full list I can't be sure, currently quite a few are not although showtime is with the right keys as is Premiere 19E, TPS & Polsat 13E and Digi TV 1W. The 2.3 cam can also get Canal Digital 1W. Biss is always a problem, with the Diablo, as the file set up only allows you to view the first channel in the list if biss channels use the same recognition coding. Some of the others listed only allow some channels, like TCM 13E, TCM 19E, Cartoon Network 19E, and Hustler 5E, not all channels in some of the listed packages are available, except for the ones I have listed, Premiere 19E, Polsat & TPS 13E, Digi TV and Canal Digital 1W, but Canal Digital is only available on the 2.3 cam using underworld 108. I hope this helps and isn't too confusing, but there's plenty of viewing choices, depending on which satellites you can receive. | ||
| The Following User Says Thank You to Mickha For This Useful Post: | slimsim (10-05-2008) |
