T-rex and canal digitaalSatellite TV support fourm for X-CAM, Ultra CAM, Dragon CAM, Diablo, T Rex. | |
| Member Join Date: 21-05-2008 Location: turkey
My System: trex |
Hi, I have a question and i hope some one has the answer. I want to buy a canal digitaal card next time i go to holland. I understood it works in t-rex (4.6) cam. But also I understood that to activate the card it has to be in offical cam. Is this true? If this is the case, I'll try to find somebody in holland who has canal digital receiver and use his to activate the card, but i dont want to go to all the throuble if it is not needed. Regards Yakup | ||
Welcome to the forum yakup72 My understanding of the situation is that without an address in Holland you will not be able to buy a card, but I may be wrong, why not search the forum it has been discussed many times before see here | ||
My System: trex | Hi Topper, Thank you for the reply. I have an adress in Holland and a bank account (because I'm Dutch), so it will not be any problem. It's just the technical issue of getting it activated. Regards | ||
| Archived Member Join Date: 13-08-2007 Location: Middle East - Israel
| Good morning yakup72, Do you have already a dish pointing to Astra 19.2E and are receiving all the channels in the Canal Digitaal package OK? The reason I am asking is that in my location I need a really large dish for this package, but if you have already a setup then you should have no problem if and when you buy a smartcard. What is the size of the dish, by the way? As regarding the subscription, I have seen this card being sold with all kind of options and without a dedicated receiver, so I am not sure if you really need a dedicated receiver to activate it. | ||
| | #5 | ||
My System: trex | Hi HB13, Yes, I do receive some channels of canaal digitaal. 2 transponders have been changed so now i can receive them with 80cm dish in Istanbul. It's not all the channels, but most of the ones that are in the cheepest set top box packet, so i will go for that. Maybe Israel is out of the reach, but you should do a rescan, because this transponder change is maybe happend 1 week ago | ||
| canal, digitaal, trex |
