Underworld 143
Thread Tools Display Modes
Old 04-11-2008   #1
Underworld 143
Underworld 143 is now available:
What's New??
_____________________________________________
«NeW» exclusive Sex View - Hotbird 6/7A/8 (13°E)(works only in Diablo version 2.3)
«FiX» Updated Version Expiration Date
«FiX» TCP and DNS bug Fixed (Minor Bug)
XclusiVe E M Us
»All Vers.« Irdeto2: Free X TV - Hotbird 6/7A/8 (13°E)
»All Vers.« Irdeto2: Sex View - Hotbird 6/7A/8 (13°E)
»All Vers.« Irdeto2: LA7 - Atlantic Bird 1 (12.5°W)
»Version 2.3 ONLY« Conax: Canaal Digital Nordic - Thor 3/5 (0.8°W)
»Version 2.3 ONLY« Conax: DigitAlb - Eutelsat W2 (16.0E)
!! Coming S00N a BIG BOMB AGAIN - STAY TUNED........
__________________
Mickha is offline   Reply With Quote
Old 04-11-2008   #2
Llew's Avatar
My System: Triple Dragon with HDD/USB stick, Humax HDCI2000, Echostar AD3000ip & SR8700, Fortecstar 5100CIUltra, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. Diablo/Mrev Cams
Thanks, haven't tried it yet, but the reference to Version 2.3 openings - does that mean Version 2.2 won't do Canal+ now?
__________________
Llew is offline   Reply With Quote
Old 04-11-2008   #3
Llew's Avatar
Oops, just remembered, I updated it to 2.3
__________________
Old 05-11-2008   #4
My System: Topfield 7700 HSCI
Underworld 143 and Irdeto 2
Hi friends,
I can watch the channels in Conax (16ºE and 1ºW), Premiere, Polsat, etc,,,with Underworld 143 but not Sex View channels and Free ***TV. ¿Somebody can watch it? ¿Is necesary some special configuration?
Thanks from Spain
jeivi is offline   Reply With Quote
Old 06-11-2008   #5
My System: tm-1000d,80 cm Dish, univrsl lnb.
Ello mate Good Job u guys are doing.I new to satelite and have read alot of forum stuff.my questn is apart from using softcam to view the channels, do u have any other parallel solution like cam, diablo ,underworld. how can this stuff be used to decode scramble channels?.cheers
skiiipo is offline   Reply With Quote
Old 06-11-2008   #6
Your patched Technomate receiver will currently open the following main packages:
Premiere 19E, changing to N3 encryption very soon
Polsat 13E
Digi TV 1W
A Diablo 2.3 Cam will also currently open
DigitAlb 16E
SexView 13E
Canal Digital 1W
An 80cm dish might be alright to receive all the channels, depending where you are roughly located in the UK.
__________________
Old 06-11-2008   #7
tanx for ur answer, if u can explain to me how diablo work (2.3) works i will appreciate it tanx. my loctn SW England.
Old 06-11-2008   #8
I have been trying to find the technical specifications concerning your receiver, the Technomate 1000d, without a lot of success.
I'm beginning to think your receiver hasn't got a CI, Common Interface, slot for a Cam, if it hasn't you would need a different receiver for the Diablo Cam.
Can you please check your receivers manual to see if it has a CI slot, or even a card reader.
__________________
Old 07-11-2008   #9
NO hasnt got CI ,
Old 07-11-2008   #10
i want to upgrade it to a receiver wt a CI. SO i ask again if u can explain to me how to programme or the science beyind the diablo,underworld's ability to decode scrambles.cheers. And if u can explain to me or tru a video tutorial on how to manually enter keys to technomate receiver.I read some site but couldnt understand what is line 00 or 1o. i will appreciate it if u could help.
Old 07-11-2008   #11
To program a Diablo Cam you require a Cas programmer, I recommend the Cas 3+, as this can program both cams and cards.
You need to ask other Technomate users how to manually enter keys into a Technomate receiver, or search the forum.
I shall try to post a more detailed explanation over the weekend, when I'm not so busy at work, but if you have time have a read through some other threads as most subjects have already been covered,
__________________
Old 07-11-2008   #12
Turok's Avatar
My System: 1,25 Fibostop Jäger Smr 1224 Dual Axsis Echostar Dvr 7000 Monterey 140 Tagra 2,20 M Fullsize Dish Echostar 2,40m Mesch for cband!
big bomb,sounds like a surprise,comes showtime back to us
Turok is offline   Reply With Quote
Old 07-11-2008   #13
peterscott66's Avatar
My System: Technomate 1000, 1m motorised dish, 42" plasma, wii, xbox 360, ps3.
Help
just upgrded cam to 2.3, were can i download underworld 143
XclusiVe E M Us
!! Coming S00N a BIG BOMB AGAIN - STAY TUNED........[/quote]
peterscott66 is offline   Reply With Quote
Forum Jump
All views and information expressed in users' communications and profiles represent the opinions of the users concerned and do not represent the views of Satellites.co.uk. All images and news content are believed to be in the public domain, except where otherwise stated. Forum software by vBulletin® Version 3.8.0
