Diablo light | |
| Member Join Date: 05-11-2008 Location: n.Ireland
My System: Echostar receiver with motorised 2m dish |
Hi all I have just bought the diablo light cam with cas 3+ programmer . I have put the 1.43 file on the cam but i cannot get the premier channels on it just says insert smart card. But if i put in my old dragon cam the channel comes on o.k. I have an echostar 3600 with a 2m motorised dish. I normally program the dragon cam and dont have any trouble. Thanks for your Help Chris. | ||
| Super Moderator Join Date: 10-12-2004
![]() | After programming the Diablo Cam you have to set the configuration settings. Enter the Cams Menu, enter the configuration folder and ensure that Emulators and N2 AU are both set to ON. Once done you should get the keys have expired message, and the keys should auto update within 5-10 minutes. Once the keys are updated you can switch channels normally. | ||
Hi Mickha Everything is working fine now i just loaded the 1.43 file without writing the latest key files afterwards . I was most likely putting files in that i shouldnt have. Thanks very much for your Help Much appreciated chris. | ||
