What can I get with my Diablo? | |
| Member Join Date: 22-03-2008 Location: stockton on tees
My System: Technomate 1000, 1m motorised dish, 42" plasma, wii, xbox 360, ps3. |
Got my diablo 2.3 card up and running with the latest software, anyone know exactly what channels i can recieve or how to find out? | ||
| Super Moderator Join Date: 10-12-2004
![]() | With the Diablo 2.3 Cam loaded with underworld 144 you can currently open the following main packages: Premiere 19E, soon will be switching to Nagra 3 encryption, so wont be available, and some channels have already changed. DigitAlb 16E, excepth the HD channels Sexview 13E Polsat 13E Digi TV 1W Canal Digital 1W Go to lyngsat.com and click on the packages links, that correspond to the satellite position, to see all the channels available in the various packages. | ||
| The Following User Says Thank You to Mickha For This Useful Post: | peterscott66 (08-11-2008) |
My System: Technomate 1000, 1m motorised dish, 42" plasma, wii, xbox 360, ps3. | I am getting a message that my keys have expired? i only got it working last night. What do i do? | ||
![]() | It depends which channel you're trying to view. The keys expired message does appear when the Cam is Auto Updating the keys, for Digi TV, Premiere and Polsat, all channels using Nagra 2 encryption, this unitially takes 5-10 minutes then once the keys have updated you can view the channels as normal. When switching between channels, especially different packages, the Cam does occasionally lock up, but by simply removing and re-inserting the cam it starts working again. Please post more details of the channels you're trying to view, and check in the cams menu, configuration folder, that you have N2 AU and Emulators both turned ON. | ||
| | #5 | ||
| Regular Member Join Date: 21-01-2005
Hi, Got my diablo cam,install uw144 ,update keys ,open all channels possible but when I try to watch a channels after a while(5,10,15.....min.) freezes up .Can`t see a hole movie.Any ideas? | ||
| | #6 | ||
![]() | It would help a lot if you mentioned which receiver you're using. The Diablo Cam does run quite hot and so there has to be plenty of ventilation around the receiver, I have my receiver raised about an inch using blocks under the 4 corners, I also don't have any other electrical equipment underneath it, as this also heats the cam and receiver. The cam seems to work better in the bottom CI slot, if you have a receiver with 2 slots, also if your receiver is patched turn off the patch. Remove any other cam or card if you have one installed. | ||
