Underworld 145 | |
| Super Moderator Join Date: 10-12-2004
Underworld 145 is now available: What's New?? _____________________________________________ ¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯ «KeyUpdate» LA7 - Atlantic Bird 1 (12.5°W) «KeyUpdate» Free X TV - Hotbird 6/7A/8 (13°E) N.B. Added sono update info on the bottom of this document ______________________________ XclusiVe E M Us ¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯ »All Vers.« Irdeto2: Free X TV - Hotbird 6/7A/8 (13°E) »All Vers.« Irdeto2: LA7 - Atlantic Bird 1 (12.5°W) »Version 2.3 ONLY« Conax: Canaal Digital Nordic - Thor 3/5 (0.8°W) »Version 2.3 ONLY« Conax: DigitAlb - Eutelsat W2 (16.0E) !! Coming S00N a BIG BOMB AGAIN - DON'T PANIC !! | ||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Humax HDCI2000, Echostar AD3000ip & SR8700, Fortecstar 5100CIUltra, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. Diablo/Mrev Cams ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | Any idea what the the 'sono update' referred to there is Mickha? Llew | ||
![]() | There's a long read me file, in with this update, but it just looked like the old information, how to program the cam, settings best used, what cards are supported and one piece of important information, regarding future updates, stating that from now on they will only release data bin files, when it's just a keys update, not a new underworld file. | ||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Humax HDCI2000, Echostar AD3000ip & SR8700, Fortecstar 5100CIUltra, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. Diablo/Mrev Cams ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | OK cheers. Possibly a new underworld version might give us a little extra - even the Big Bomb Llew | ||
| | #5 | ||
| Member Join Date: 21-05-2008 Location: United Kingdom
My System: Laptop Computer, Cable Satellite | hi tehre ive put the latest underworld update onto my cam but i cnt get anything. none of the channels wwork same on my dragon loader card. anyone know whats wrong with these or am i going wrong anywhere? any help will be much appreciated. thanks. | ||
| | #6 | ||
![]() | Hi Killa_K, your post is a little confusing as a Dragon Loader Card has nothing to do with a Diablo 2.3 cam. Have you got a Diablo 2.3 Cam or a Dragon Cam? If you have loaded underworld 145 onto your Diablo 2.3 cam check the configuration settings: Enter the Diablo 2.3 cams menu using your receivers cam options. Enter Underworld 145 and enter the configuration folder, change Emultors and N2 AU to ON and your cam should work. To get Sexview you will have to load the updated Data bin file onto your cam. Please post back with more precise details regarding your problem. | ||
| The Following User Says Thank You to Mickha For This Useful Post: | dublindanny (16-11-2008) |
| | #8 | ||
![]() | You don't, no files or keys are allowed on the forum. If you type underworld145 into a search engine, or check the links section, part of our forum, you should soon find it. | ||
