Dragon Cam on Phoenix Apollo
Thread Tools Display Modes
Old 15-11-2008   #1
My System: phoenix apollo receiver, motorised dish
Hi..I have been using dragon cam on phoenix apollo receiver and when i reloaded the latest predator 3.69 none of the channels seem to be opneing..i can get to the predator menu and see correct codes there..any way i can either check what is wrong with it or reset the cam?
al_k is offline   Reply With Quote
Old 15-11-2008   #2
Amo Amas Amant Admin
Topper's Avatar
Well
Go on then give us a clue which satellite are you on and which channels are not opening.... wouldn't be Premier by any chance would it?
__________________
Formerly toppervte33h
Show Your Support
by clicking the button
Thank you.
Freddie Flintoff is back
Old 15-11-2008   #3
Not premiere..though it was the reason i reloaded predator..understand it is down now...tried eurosport, polsat, etc...basically none are opening..if you can suggest a version of predtaor to use or how can i check whether this is a problem with receiver software, etc?
Old 15-11-2008   #4
Load the original Pedator 369 by kinkdink, if you search the internet for predator369 you should find it, once loaded ensrure that N2 AU is ON in the menu under Settings, then leave it on a Polsat channel for a few minutes.
Currently the main packages available, on the Dragon Cam, are Polsat 13E and Digi TV 1W.
__________________
Mickha is offline   Reply With Quote
Old 16-11-2008   #5
worked fine, thanks a lot
Forum Jump
All views and information expressed in users' communications and profiles represent the opinions of the users concerned and do not represent the views of Satellites.co.uk. All images and news content are believed to be in the public domain, except where otherwise stated. Forum software by vBulletin® Version 3.8.0
