Diablo 2.3 and Humax 5400 problem
Thread Tools Display Modes
Old 21-11-2008   #1
My System: Humax IRCI-5400, 1.2m Precision dish, El1224 mount
Hi guys,
I have a Humax 5400 patched with the latest HOT emu loaded. I purchased a Diablo 2.3 which I programmed with Underword 1.46 using a CAS3 programmer. With the CAM inserted the Humax comes up with 'Initialising CI module' and freezes most of the time. Other times it clears the channel but I cant change channel after that, it sounds like it freezes again... I tried the Cam it both slots with the same results
I would appreciate any help.
Thanks.
greg_f is offline   Reply With Quote
Old 22-11-2008   #2
My System: motorised technomate rx i meter dish dragon cam etc
I think you'll find the diablo work's fine if you turn your patch off m8..
regard's
terry.
terry w l is offline   Reply With Quote
Old 22-11-2008   #3
Thanks mate, I will try to upload the original firmware and I will let you know.
Old 22-11-2008   #4
Turok's Avatar
My System: 1,25 Fibostop Jäger Smr 1224 Dual Axsis Echostar Dvr 7000 Monterey 140 Tagra 2,20 M Fullsize Dish Echostar 2,40m Mesch for cband!
hello!
is this a orginal diablo rev 2.3.or a older 2.2 rev.where you have upgraded online,to rev 2.3?
i have do this with mine,and since that,on some stbs like my xtreme hornet,the signal already is good ,but the pircutre on 1 west are full of artefacts,like on low signal,seems to be,that the compatibly to difrent stbs,is much lower,on rev 2.3 then on old rev 2.2!
Turok is offline   Reply With Quote
Old 22-11-2008   #5
Well i'm using a 2.2 upgraded to a 2.3 in a topfield tf7710 and a technomate.. at the moment using Underworld 146 but will be upgrading to 147 [now it's out].. working fine using no patches..
regard's
terry.
Old 22-11-2008   #6
Well, I tried it with no patches, I downloaded the original Humax firmware, still the same result. It seems that the Humax freezes at the 'Initialising CI module'. Unfortunately I havent got another receiver/CAM to try. I am wondering if my Humax has a problem
Old 25-11-2008   #7
So you've turned your patch off gone to humax confiuration set cas to 123456..
loaded diablo cam with underworld 1,46 gone into common interface menu gone into underworld 1.46 menu goneto cas and turned every thing off
conax
seca
ideto
viacess
cryptoworks
also dreamcrypt and nagravision
then went to configuration and set at,
language english
cairds file [cairds]
auto pmt [on]
emulators [on]
n2 au [on]
emulators priority 1 [cards-2 emu]
fixed cw [off]
smartcard message [show never]..
and it still didn't.work?..strange !!..
Old 26-11-2008   #8
Hello Terry,
thank you again for all your help. The settings that you suggest is exactly what I have! I noticed that if I stay on an FTA channel the Humax doesnt freeze, if I go to an encrypted one the CAM initiliases and clears the channel. The problem is that after few seconds maybe even a minute, while the channel stays clear and everything seems fine, I still cant change channel or do any other operation on the Humax. Strange...
Forum Jump
All views and information expressed in users' communications and profiles represent the opinions of the users concerned and do not represent the views of Satellites.co.uk. All images and news content are believed to be in the public domain, except where otherwise stated. Forum software by vBulletin® Version 3.8.0
