Underworld 148
Thread Tools Display Modes
Old 26-11-2008   #1
Underworld 148
Underworld 148 is now available:
What's New??
_____________________________________________
Emulators fixed:
DigitAlb-Sex View-FreeX-Canaal Digital Nordic
XclusiVe E M Us
»All Vers.« Irdeto2: Free X TV - Hotbird 6/7A/8 (13°E)
»All Vers.« Irdeto2: LA7 - Atlantic Bird 1 (12.5°W)
»Version 2.3 ONLY« Irdeto2: Sex View - Hotbird 6/7A/8 (13°E)
»Version 2.3 ONLY« Conax: Kabelkiosk - Atlantic Bird 2/Telecom 2D (8°W)
»Version 2.3 ONLY« Conax: Canaal Digital Nordic - Thor 3/5 (0.8°W)
»Version 2.3 ONLY« Conax: DigitAlb - Eutelsat W2 (16.0E)
__________________
Mickha is offline   Reply With Quote
Old 26-11-2008   #2
Llew's Avatar
My System: Triple Dragon with HDD/USB stick, Humax HDCI2000, Echostar AD3000ip & SR8700, Fortecstar 5100CIUltra, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. Diablo/Mrev Cams
OK on mine apart from the Conax channels on 19E 12.031H.
__________________
Llew is offline   Reply With Quote
Old 26-11-2008   #3
Salty Tech Monster Mod
waverider's Avatar
My System: TM-5400 CI+USB Super. Cryptik Digital H-H Mount. Diablo 2.3 Light. Cas 3+
147 not clearing conax on Thor. Think I'll give 148 a try!
waverider is offline   Reply With Quote
Old 27-11-2008   #4
ayp
My System: Manhattan Plaza ST500 1.2m Dish Manhattan/Stab HH120 Diseqc Motor Diablo/Dragon Cams
underworld 148
Conax/nagra not clearing on Thor, gone back to underworld 147 which works fine on nagra.
ayp is offline   Reply With Quote
Old 27-11-2008   #5
colinp's Avatar
My System: 1.2m motorised qualitv decoder manhatten blind search decoder echostar 3600ip
Check your settings in configurations ayp as I have been watching Natgeo hd on 1 west this morning.
colinp is offline   Reply With Quote
Old 27-11-2008   #6
Underworld 148 is clearing the channels, try formatting your cam, re-loading underworld 148 and adjusting your configuration settings.
__________________
Old 27-11-2008   #7
waverider's Avatar
148 working ok, but did hear from a good source that canal was down for a short while the other day!
The Following User Says Thank You to waverider For This Useful Post:
albert45 (29-11-2008)
Old 29-11-2008   #8
peterscott66's Avatar
My System: Technomate 1000, 1m motorised dish, 42" plasma, wii, xbox 360, ps3.
underworld 148 not working
have updated mt diablo cam to 148 and getting the "please insert cam" message. i have obviously done something wrong. any ideas?
peterscott66 is offline   Reply With Quote
Old 29-11-2008   #9
ignore last
ignore last post, didnt turn the emulaters back on!
Old 29-11-2008   #10
My System: GBsat Duet + Diablo 2.2 Mac Mini, PC Wifi (g)
Hi guys,
Am I correct to think that Diablo 2.2 will no longer unlock Prem**re package? If so, does a Diablo 2.3 do the trick?
I was looking at the diablo cam site and it seems they no have a wifi version, which appears to be a standard diablo lite with a wifi g connection. Presumably this still functions as a standard diablo and one can update the firmware with a CAS 3 programmer as for the diablo 2.2. However, duolabs also mention the potential to stream video over the local wifi subnet - has anyone tried this?
thanks for your help
skipppington is offline   Reply With Quote
Old 29-11-2008   #11
The main Premiere channels are no longer available as they have upgraded to Nagra 3, only a subscription will currently get them, the Diablo 2.3 can open the few channels still using the old Conax encryption.
The Wi Fi needs to be programmed using the Cas programmer, to load Underworld firmware, but you can use the Wi Fi feature to update the data, and key, bin files from your computer.
For more details check diablocam.com as they have a downloadable file with more information on their cams.
There is also the new Q Box HD due out soon, a Linux receiver with a built in Diablo cam.
__________________
The Following User Says Thank You to Mickha For This Useful Post:
skipppington (29-11-2008)
Forum Jump
All views and information expressed in users' communications and profiles represent the opinions of the users concerned and do not represent the views of Satellites.co.uk. All images and news content are believed to be in the public domain, except where otherwise stated. Forum software by vBulletin® Version 3.8.0
