Second Diablo data bin file 10/12
Satellite TV support fourm for X-CAM, Ultra CAM, Dragon CAM, Diablo, T Rex.
Old 10-12-2008   #1
There has been another new Diablo data bin file released today, 10/12, this time with a fix for DigitAlb, but, from posts I've read, Sex View seems to be down again.
We might even end up with 3 new data bin file releases in one day !!!!!!
Mickha is offline   Reply With Quote
Old 13-12-2008   #2
My System: MOTORISED TECHNOMATE
Hi
i have update my daiblo cam with underworld 149 - but the thing still wont open channels where do i found the bin files that i think i need
BRIDGET69 is offline   Reply With Quote
Old 13-12-2008   #3
The last data bin file was released on the 11/12, but sex view and Kabel Kiosk are both currently down.
Which channels are you trying to open?
Old 14-12-2008   #4
hi
i am trying to open eutelsat
Old 14-12-2008   #5
The only Eutelsat, that I'm aware of, is the name of a satellite, of which there are many, are you trying to open DigitAlb on Eutelsat W2 16E ?
Old 15-12-2008   #6
hi
yes i am trying to open digitalb16 e iopen other conax channels on other satellites but not this one
many thanks
Old 15-12-2008   #7
Load the latest data bin file onto your cam:
Diablo data bin file 13/12
Download this file and use winrar, or 7-zip, to uncompress it.
Extract the data bin file to your computer desktop.
Insert your Diablo Cam into your Cas programmer.
Start up the Cas Studio and the Diablo Cam software.
Click on the Cam File System tab, and click Connect.
In the right hand pane you should now see the current files loaded on your Diablo Cam.
In the bottom left hand pane locate the new data.bin file, highlight it, and click the green arrow pointing right.
Click Yes to overwrite the old file, which only takes a couple of seconds.
Once complete disconnect, exit the software and your Cam should now open DigitAlb.
10 or 12, bin, data, diablo, file
