Diablo lock up
Satellite TV support fourm for X-CAM, Ultra CAM, Dragon CAM, Diablo, T Rex.
Old 29-12-2008   #1
kenny1234's Avatar
My System: Motorised ASC 1.2m,1224 Supermount with C120 Invacom Quad LNB with Matched Feedhorn.
Diablo lock up
Anyone know why my diablo runs spot on all day no lock up, but whenever i set record overnight it locks up missed ufc AGAIN GRRRRR.
Running latest underworld and darkman patch on tm6900 super combo
Do i have to disable patch to stop interference with diablo? if so how i cant rem sure i read it had something to do with typing 2004 or 8281
kenny1234 is offline   Reply With Quote
Old 29-12-2008   #2
I think in the Technomate receivers you have to hit menu and type 2004.
Are you using the timer function, on the receiver, or do you leave it running?
Have you checked the temperature, as the Diablo Cam runs quite hot and can freeze when it gets too hot.
I have my receiver raised about 1 inch, by placing blocks under each corner of the receiver, to allow airflow underneath, others have fitted fans.
Mickha is offline   Reply With Quote
The Following User Says Thank You to Mickha For This Useful Post:
kenny1234 (29-12-2008)
Old 29-12-2008   #3
kenny1234's Avatar
Just leave it running mate all cool nothing near tm ill try 2004in menu
diablo, lock
