Diablo technical questionSatellite TV support fourm for X-CAM, Ultra CAM, Dragon CAM, Diablo, T Rex. | |
| Member Join Date: 23-03-2008 Location: cheshire
My System: satellite |
As usual I am trying all the keys files I can find and have upgraded to to underworld 158 but only clearing a few channels. When I look at the keys edit through cas interface many of the listed keys have no encryption codes only a series of zeros which indicates to me that even though the channels are listed in the key idents lists no keys really exist. However I might be misunderstanding how diablo works or something. So to my question, does diablo somehow update the blank key files by leaving it on a particular channel to clear or is it the case that if the keys edit lists a row of zeros then there is no hope of clearing the channel listed until you have edited the zeros manualy with the correct encryption code which is a tedious task even if you can find the codes posted on some web site in the first place. So can anyone enlighten me please. | ||
| Super Moderator Join Date: 10-12-2004
![]() | The Diablo used to be AU (Auto Update) for Digi TV 1W, but the providers knocked this option out. AT the moment the Diablo opens the following main packages: DigitAlb 16E, but not the HD channels Canal Digital 1W Digi TV 1W For DigitAlb you need to load the latest data bin file, 29/1. For Digi TV you need to ensure that N2 AU is turned OFF in the configuration menu and then update the keys or load the latest keys bin file, if you have N2 AU turned ON the correct keys will be overwritten. | ||
| Member Join Date: 23-11-2008 Location: finland
My System: samsung 9500 windows xp |
Underworld 158. Includes Keys: Smartcard info: Cas: Conficuration: Utilities and Cam info. Conficuration = English ;Caids file = Caids; Auto PMT = off; Emulators = on; N2AU= off; Emulators priority = 1 emu ; 2 cards ; Fixed CW= on; Smartcard Mess = Show never. Under CAS all are ON but seca and dreamcrypt are OFF. I have these on diablo, but i cant open any channells? | ||
![]() | For DigitAlb, 16E, you need to load the data bin file from 29/1. For Digi TV, 1W, you need to leave N2 AU OFF but update the keys bin file or manually update the keys. You don't need to do anything for Canal Digital you don't need to do anything except turn Emulators ON. Which channels are you trying to open? | ||
| | #5 | ||
My System: samsung 9500 windows xp | Hello I tried all from _http://www.lyngsat.com/packages/canaldigital.html No one open only few free channells. Where could i get such files which open these conax scrambled channells? Thanks | ||
| | #6 | ||
| Member Join Date: 25-07-2006 Location: north east
My System: satellite on astra 19.2 fixed dish,technosat d digit mf4-s reciever technomate 5400 usb sat on 1w diablo,trex and various cards | Canaldigital down as from early this morning, no conax open on thor only nagra channels, hopefully a fix soon | ||
| | #8 | ||
My System: satellite on astra 19.2 fixed dish,technosat d digit mf4-s reciever technomate 5400 usb sat on 1w diablo,trex and various cards | been on holiday and just loaded underworld 172 and latest key file, however conax clears fine but nagra keeps losing signal, cams au is off is there a tutorial of how to input keys manually step by step. Ive a tm 5400 super | ||
| | #9 | ||
![]() | If your Technomate is patched turn the patch off, as this can cause problems, or remove the cam and use the patch to watch Digi TV, as I think the patch is still AU (Auto Updating). To manually enter the keys in the Diablo Cam, enter the cams menu, using your receivers options, and the following sub menus: Underworld 172 Keys List Keys Edit Nagravision 2 Digi TV Key 96 (Key 01) Press enter, or OK, on your remote and you get 2 options on how you wish to manually enter the keys. Hexadecimal or Decimal, I prefer Decimal as I find it quicker. | ||
| The Following User Says Thank You to Mickha For This Useful Post: | eddik (27-04-2009) |
| diablo, question, technical |
