Underworld 164Satellite TV support fourm for X-CAM, Ultra CAM, Dragon CAM, Diablo, T Rex. | |
| Super Moderator Join Date: 10-12-2004
Underworld 164 is now available. Canal Digital updated. From the read me file: ***************************** ** THE BIG THING! ** ** CCCam in Diablo Wi-Fi!! ** ***************************** Finally available the CCCam protocol on Diablo Wi-Fi from UnderWorld 1.63. What does it mean?? Freedom of using ANY receiver like a DreamBox. Thanks to the Wi-Fi LAN embedded in the Diablo Wi-Fi when you connect it to ANY Common Interface Receiver it will work like a DreamBox and enchances all the s****ing features that DreamBox is offering in "exclusive" up to today but... NOW with the big advantage that you can use you own Common Interface receiver that you are familiar with and you like most, High Definition too!! You can configure the CCCam as the DreamBox CCCam. You simply copy and paste the same config string as you are using in your DreamBox. Do not forget that even the other protocols are working as well like GBox, NewCamD and Radegast. The Diablo Wi-Fi will act as card client or either Card Server! You are not dreaming this is pure reality! | ||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | Thanks Micha, Canal channels due for an update I gather. Llew | ||
| Member Join Date: 06-03-2009 Location: S Wales
My System: Sky UK + 1.2 Mtr dish TM 1500 | Came around for an update check and saw Mickha's. As a newbie, I'm not sure what the implications are. Does this mean the "stuff" posted in the DB Ccam forums, such as Canal+ viaccess 3 will be available to all those with Diablo wi-fi, or do we need access to a DB Ccam to get the config strings? What can the "average" sat person expect to get from this new protocol? Oh and is it just me, or have we lost S1, 2 and 3 plus 9E? Don't seem to open with the new UW 1.64..... | ||
| | #5 | ||
| Member Join Date: 09-04-2009 Location: turkey
My System: Finepass 5000 dreambox 800 sharp hd1e | Hi Mickha, finally got my wifi diablocam, seems to work but doesn't decode anything, Probably a dumb question to you: but how do you copy the config string from the dreambox to the cam? Cheers yusat ;-) | ||
| | #6 | ||
![]() | You have to use your PC/laptop, and Cas programmer. Start up the Cas Studio software, the Diablo Cam software and click on the Cam File Systems tab. Gagliostro produced a quick set up guide that might be helpful: _http://www.sendspace.com/file/j94f71 | ||
| | #7 | ||
My System: Finepass 5000 dreambox 800 sharp hd1e | Thanks Mickha for the quick responseI understand for the diablo, but where do I copy it from the dreambox and what does it look like? yusat | ||
| 164, underworld |
