Underworld 170Satellite TV support fourm for X-CAM, Ultra CAM, Dragon CAM, Diablo, T Rex. | |
| Super Moderator Join Date: 10-12-2004
Underworld 170 is now available: What's New?? _____________________________________________ ______________________________ XclusiVe E M Us ŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻ Underworld Team wish you a great weekend enjoing this big news: ******************************* Version 2.3 ONLYĞ Irdeto2: Canal Digitaal Holland - Astra (19°E) Version 2.3 ONLYĞ Conax: Canaal Digital Nordic - Thor 3/5 (0.8°W) | ||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | Blimey, have they opened up the Dutchies Mickha? ![]() Llew | ||
| | #5 | ||
| Specialist Contributor Join Date: 07-08-2005 Location: west yorks, uk
My System: andrews dish - jaeger 1224 motor, vantage x221tsci, skystar 2, diablo v2.3, cyfra+ | yep these are open with diablo cam 12304h, 12344h, 12515h, 12574h, 12722h | ||
| | #6 | ||
| Member Join Date: 11-12-2008 Location: essex
My System: home built computer,passion hd stb,techomate 5200 super,1mt motorised dish | 12304= 2 channels only 12344/12515/12574 =yes 12722= 4 channels only "irdeto 2" channels hope that helps | ||
| | #7 | ||
| Member Join Date: 06-03-2009 Location: S Wales
My System: Sky UK + 1.2 Mtr dish TM 1500 | This is great news for me! I've badly missed Dutch tv, as it caters for an interest of mine. All working nicely. Hopefully, this will last and not be a one off! | ||
| | #10 | ||
![]() | Try formatting your cam, loading Underworld 170 and nothing else, it contains a data and keys bi8n file and any updated keys bin file needs to be from Underworld 170. Don't forget to turn Emulators ON, in the configuration folder, after formatting. Try RTL 4 on 19.2E. | ||
| | #13 | ||
![]() | Check you have Emulators turned on in the Configuration menu, or try removing and re-inserting your cam or re-booting your receiver. You can also try an updated keys bin file, which have helped some people, but make sure it's a latest keys bin file. | ||
| | #14 | ||
My System: andrews dish - jaeger 1224 motor, vantage x221tsci, skystar 2, diablo v2.3, cyfra+ | sounds like you need to load another key bin to the cam make sure its one from underworld 170 but on mine i went to 19e and selected one of the channels like rtl4 and left it for a few minutes and the channel came on like it was updating the key i think | ||
| | #17 | ||
My System: Sky UK + 1.2 Mtr dish TM 1500 | I wonder what we can expect next from the UW wizards? Assuming Iredeto follows the Conax route, more nice packages, maybe? Nova looks nice on 13E! | ||
| | #18 | ||
My System: andrews dish - jaeger 1224 motor, vantage x221tsci, skystar 2, diablo v2.3, cyfra+ | nova i doubt it as there was that trouble with shops selling gamma cards etc so i dont think it will happen, it would be nice though. | ||
| | #20 | ||
![]() | You shouldn't load a new keys, or data, bin file, try formatting your Cam and loading Underworld 170 again, ensure you turn Emulators ON in the configuration folder. If it still doesn't work try loading a later keys bin file, from EMPB, but make sure it's a modified keys bin taken from the Underworld 170 file. | ||
| | #21 | ||
| Member Join Date: 21-02-2008 Location: rotterdam, holland
My System: motorized 64cm triax dish. Topfield 5000ci, diablocam light v2.3, cas3+ | I have the same problem. I formatted the diablo, put UW170 on it... Nothing.. everything is working (Digi, Canal Digital Nordic etc) but not Canal Digital Netherlands. I put it to RTL4 for 30 min.. But nothing happens. I tried to update with a new Key file form 04/04 but no go with that. Anybody have any idea. I do have a standard legal subscription to canal digital netherlands, maybe that is working against me ? I removed this smartcard and still no go. any ideas anyone ? Youre help would be much appreciated and i will name my firstborn after you... heheh Regards Guppie73 | ||
| | #22 | ||
![]() | Try a later keys bin file by EMPB, as this seems to work for some people experiencing problems. If you formatted your Cam nad loaded Underworld 170 Digi TV shouldn't be working unless you manually updated the keys or loaded an amended keys bin file, in which case ensure it's an original keys bin file from Underworld 170 that's been updated. | ||
| | #23 | ||
Hey Mickha, Thanks for your info. Digi is/was working with just the UW170 file.. My wife is romanian and if it is not working she will kill me for sure.. so i check everytime i do or change something.. LOL In the mean time i formatted the cam again.. Put UW170 on it and then i updated the keys and conax file from EMPB.. (it is from his 07/04 update. In this update he specially mentions all the do's and dont's for Canal Digital Netherlands). I put the cam back in my receiver.. turn it to RTL 4, veronica, etc but NOTHING... any more ideas. Youre help is much appriciated. Guppie73 | ||
| | #25 | ||
![]() | Try changing the CAIDS option, go into the Cams menu, Underworld 170, Configuration, Caids File and try changing it to Astra_1. If you are fomatting your Cam you shouldn't be able to clear Digi TV as the previous Underworld files never contained the latest keys, although I never checked with Underworld 170, and N2 AU no longer works. After formatting and loading Underworld 170 have you manually entered the latest keys or have you been updating the keys bin file? | ||
| 170, underworld |
