Predator 370 & Predasaur 230
Satellite TV support fourm for X-CAM, Ultra CAM, Dragon CAM, Diablo, T Rex.
Old 25-08-2009   #1
There are new files on the net, Predator 370 & Predasaur 230, which is very surprising.
I haven't tested them yet, but here's what's been updated, according to the read me file:
New:
Fix Swiss Viaccess card, dutch C+ card
Mickha is offline   Reply With Quote
Old 25-08-2009   #2
International Administrator
rato's Avatar
My System: DM800; Nokia 9800s; Nokia 9902S w/T-Rex 3.66 w/ Inverto IDLP-40TL + Technisat 33 dish; Pace DS430N + Humax HDCI-2000 w/ Gibertini OP 1.25m dish w/Inverto 0.3dB. & Invacom 0.2dB. w/ Spaun SAR 411; CAS 3;FUN7; SkyStar2; AltDVB;
I wonder if it can support now the Portuguese provider Meo(Seca). I couldn't with my previous versions of Predator
rato is offline   Reply With Quote
Old 03-10-2009   #3
My System: Skybox HD Humax Icord HD
right now my Predasaur is 229. How do i upload to 230. I don't have any pmcia slot in my computer.
Can i put the file into a usb key and put the usb key into the sat receiver?
sirsimontemplar is offline   Reply With Quote
Old 04-10-2009   #4
You can only load a new Predator/Predasaur file, onto a Dragon/T-Rex cam, using a loader card, Fun 7 (Prussian 5) or PIC F84a, and suitable card programmer, or you can use a Cas 3 programmer and dummy loader card.
There is no way to update it using a PMCIA slot or any other method.
Old 04-10-2009   #5
My System: predator cam, clarkteach
Hi to everybody,
i'm new one of this forum,
i can't find the way to dounloads the firmware predasaurs,
someone can write to me were I can find it?
thank you from now!!!
picet1 is offline   Reply With Quote
Old 04-10-2009   #6
Keys and files are not allowed on the forum.
If you put predasaur230, no spaces, into a search engine you will quickly find it.
Old 04-10-2009   #7
Ok, I did,
i just loads in my T-rex Super modul,
i' go on the menu->secure uploads,
comming the msg secure uploads ok
but any non pubblic chanel works..... : ((
other wise I programming my Cam whit
other firmware "predatorMonza"
and I now i can see some non pubblic chanel immediatly,
my questions is:
is possible something wrong? why i cannot open the non pubblic chanel
like in the second case?
thank for all
Old 04-10-2009   #8
Sorry: it was "Secure Update"
and non Uploads....
Old 04-10-2009   #9
There is nothing available using the secure update, and hasn't been for some time.
This update will open anything new, as stated in the first post it was merely a fix to work with a certain subscription card:
"Fix Swiss Viaccess card, dutch C+ card"
Any new files doesn't contain updated keys, for that you need to either load a modified Predasaur 230 file, manually update the keys, using the debug option, or update the keys, in the Predasaur file, prior to uploading, using software like PredEdit.
Old 05-10-2009   #10
Thank you.
How can i update the keys of the cam in my receiver.
It's a humax icord HD, there is a lign inside the cam called nagra box keys, i've been inside but they ask letters and don't know how to do that with my humax remote controle?
Is there a tutorial somewhere on how tu change keys with a humax remote controle?
Old 05-10-2009   #11
To update keys, in the Dragon/T-Rex Cam you need to convert the Hex keys into Decimal keys.
Hex keys are a combination of numbers 0-9 and letters A-E.
Decimal keys are just numbers 0-9.
The easiest way to do this is to use a Hex-Dec key coverter:
MR Hex to Dec Key converter
An example how to update keys, in the Dragon/T-Rex cam.
In this case I will use Digi TV.
Enter the cams menu using your receiver menu options, then enter the following sub menus:
Predasaur 230
Debug
OhlAladin
Digi TV
Key 00-0 enter the first 8 sets of decimal keys, 8 sets of 3 numbers.
Once complete enter key 00-1 and enter the second 8 sets of Decimal keys.
Once complete exit the menu.
If the new key is Key 01 enter the keys in 01-0 and 01-1.
Old 05-10-2009   #12
Thank you but the fil given, matrix keyer, i can't unzip it it makes me an error...
Old 05-10-2009   #13
Just checked it and I can open it using both Winzip and Winrar, what utility are you using?
Try 7-zip it's a free utility.
230, 370, predasaur, predator
