diablo and darkman
Satellite TV support fourm for X-CAM, Ultra CAM, Dragon CAM, Diablo, T Rex.
Old 25-08-2009   #1
peterscott66's Avatar
My System: Technomate 1000, 1m motorised dish, 42" plasma, wii, xbox 360, ps3.
diablo and darkman
Hi Again
Need to get digi tv, keep giving up.
I have a TM 1500 CI+ Box wich i have installed the latest patch.
when i go to system info it wont let me in, even when i press 2004
i have a diablo CAM installed with underworld 182
What else do i need?
is there an idiots guide to getting digi tv?
Peter
peterscott66 is offline   Reply With Quote
Old 25-08-2009   #2
You just require the latest keys, the last key change was 23/07/09, Key 01 (Key 96).
You can either manually enter them, in the Diablo Cam, or load an updated Diablo keys bin file.
To enter them in the Diablo, you need to enter the cams menu, via your receivers options, then enter the following sub menus:
Underworld 182
Keys
List Keys Edit
Nagravision 2
002111 Digi TV
Key 96 (key 01)
Press Enter/OK on your receivers remote and you get 2 options of how you would like to update the keys:
1 Hexadecimal
2 Decimal
I prefer Decimal, as it is quicker, but either works.
Once done you can exit.
If you already have the latest keys just ensure that Emulators is turned ON in the Configuration menu.
Mickha is offline   Reply With Quote
The Following User Says Thank You to Mickha For This Useful Post:
peterscott66 (26-08-2009)
Old 26-08-2009   #3
Did all of the above and still scrambled.... i am on the right sat..... thor 0.8w?
me thinks i must be missing something, do i need any patches for my reciever?
peter
Old 26-08-2009   #4
No but you might have to turn your patch off, are you sure you have loaded the right keys and have Emulators turned ON, and N2 AU turned OFF?
peterscott66 (27-08-2009)
Old 27-08-2009   #5
Got it! must have entered a wrong digit on my last 3 go's
Thanks again Mickha
Old 16-09-2009   #6
Hi Mickha
Formatted my cam and installed underworld 184, now ive lost digi tv, latest key update was on the 7/9. emulators on au off, any advice?
Peter
Old 16-09-2009   #7
I'd format the cam go back to Underworld 181 as the updates after that were only for subscription cards.
Digi TV is still working using the 7/9 keys.
peterscott66 (16-09-2009)
darkman, diablo
