A Couple of Diablo QuestionsSatellite TV support fourm for X-CAM, Ultra CAM, Dragon CAM, Diablo, T Rex. | |
| Member Join Date: 06-03-2009 Location: S Wales
My System: Sky UK + 1.2 Mtr dish TM 1500 |
Seems that an new UW update is a rare beast, these days and the last, 182 didn't have AU for Canal Digitaal. I had to manually load a new key bin file, a few weeks back. It must be on borrowed time by now. So, question 1) Where is the best place to find new key files, that can be opened and read? I find maually loading, is sometimes easier than programming the cam. question 2) Are there newer keys, that work with UW 182, than those posted in early August? question 3) I have seen a number of diablo key updates, that claim to open up Akta, on Sirius 4.8 I know many of these are temporarily FTA, but is there a more permenant fix? Thanks in advance.... | ||
| Super Moderator Join Date: 10-12-2004
![]() | The Diablo Cam is still AU on Canal Digitaal, but there seems to be a few problems with key bin files, or receivers. I formatted my Cam, loaded Underworld 181, and the Irdeto 2 encrypted channels on Canal Digitaal were working again. Why not produce your own keys bin files, they are quite easy to do using Fausto, although there aren't a lot of channels open at the moment. If you don't want to produce your own you can find lots of keys bin files, produced by other satellite enthusiasts, usually in the same places you find your Underworld files, just type underworld182 into a search engine and browse the results. I know Akta was FTA but I am unaware of any available keys for this package. | ||
My System: Sky UK + 1.2 Mtr dish TM 1500 | Thanks. No, there's not a lot left, at the moment. Just that I've noticed several downloads metioning an Akta fix for diablo. Digitaal is currently working OK. Got the latest keys, from said file, this morning, but no Akta, other than those temporary FTA. There you go. Hadn't thought of creating my key bin files..... | ||
| | #5 | ||
![]() | Just checked and my cam is still Auto Updating, using Underworld 181, if your cam isn't working they have changed keys which you can update manually. Have you got the Smartcard Message set to Show Normal, and are you getting the Keys Have Expired message? Check your configuration settings, I require Auto PMT ON and Emulators ON to get it to update. | ||
| | #6 | ||
| Specialist Contributor Join Date: 01-01-2000
| 181 is working on many diferent receivers with AU, so you don't need to add keys yourself. But with some receivers no version - 180/181/182 - will AU. | ||
| The Following User Says Thank You to Burnham Beech For This Useful Post: | peterscott66 (05-09-2009) |
| | #7 | |||
| Member Join Date: 22-03-2008 Location: stockton on tees
My System: Technomate 1000, 1m motorised dish, 42" plasma, wii, xbox 360, ps3. |
i am on the right sat, 19.2 astra? peter | |||
| | #8 | ||
![]() | Which channels are you trying to open? You can only open the Irdeto 2 encrypted Canal Digitaal channels on 19.2E. Have you ever had AU work on Canal Digitaal? If so try formatting your cam, loading Underworld 181 and then turning Emulators ON in the configuration menu, if Canal Digitaal does open then manually imput the keys for Digi TV. | ||
| The Following User Says Thank You to Mickha For This Useful Post: | peterscott66 (06-09-2009) |
| | #9 | ||
| Specialist Contributor Join Date: 25-04-2005 Location: Austria
My System: 1,25 Fibostop Jäger Smr 1224 & Smo 36 Dual Axsis Motor Dynasat F1 Monterey 140 Drembox 800 sky Pace HD Box Tagra 2,20 M Fullsize Dish Echostar 2,40m Mesh for cband! | canal digital card swap,should be soon finsish? what will they using irdeto 3? | ||
| | #11 | ||
My System: Sky UK + 1.2 Mtr dish TM 1500 | Canal Digitaal seems to have done down today and no AU for me. Do we have to wait upon a new key bin file, or have they switched off the Iredeto 2 again, maybe forever? | ||
| couple, diablo, questions |
