Ftp Access Data,and CCam Configuration in Diablo Wifi cam?
Satellite TV support fourm for X-CAM, Ultra CAM, Dragon CAM, Diablo, T Rex.
Old 04-09-2009   #1
Turok's Avatar
My System: 1,25 Fibostop Jäger Smr 1224 & Smo 36 Dual Axsis Motor Dynasat F1 Monterey 140 Drembox 800 sky Pace HD Box Tagra 2,20 M Fullsize Dish Echostar 2,40m Mesh for cband!
Hello!
Today,my diablo wifi cam arreived,currencly i am not familiar with this modul,and i want to try to cennect my dm 800 over ccam,what is the ftp access data ip for the wifi after programmed with the cas 3,and where i have to put the ccam files and cfg in,is there a special ccam version needed for this module?
thanks for your help!!
does ccam working better in the meantime ,on diablo wifi?
Turok is online now   Reply With Quote
Old 05-09-2009   #2
BombedOne's Avatar
My System: Covering 30W-105.5E range, two motors, C and Ku band. Various receivers/cards/cams/etc.
You can pre-assign IP via receiver osd or cas programmer, or use DHCP.
There's no need for username/pass via ftp. blank works ok
C line goes into emu/cccam folder, into cccam.cfg file. Use same format as on dreambox.
then go to module menu, config/addon, select ccccam.
BombedOne is offline   Reply With Quote
Old 16-09-2009   #3
Turok's Avatar
Hello!
i programmed now my wifi cam,but i still cannot connect to my dm 800,
enter the dns server,ip data everything needed
gateway subnet,wpa encryption of my router,and the access key!
,ccam activated in menu,router found,connected i see the lamp blinking of wlan on the dsl router ,and diablo,but still no connect manuall and also with dhcp!
ccam is already installed in underworld 1.84 so what could be the problem?
the access rights of cfg maybe diffrent in diablo from 644 for the cfg?
router found in menu menu,but when i click ccam and try to search them nothing happens, i try the first and secundary dns of my isp,but both not work,any ideas,what it could be?
thanks for your input!
access, cam, ccam, configuration, data, diablo, ftp, wifi
