Cam
Satellite TV support fourm for X-CAM, Ultra CAM, Dragon CAM, Diablo, T Rex.
Old 05-09-2009   #1
Nolia's Avatar
My System: Moterk 2100a motor on 80cm dish,16'E-18'W Manhattan XT-CM receiver. Fixed Sky dish 28'2E
Cam
is there such a thing called universal CAM?? I will be getting a Bravia TV nx wk and would want to use my cyfra card,digi tv and sky card in it as it has a Mpeg4 tuner(hd tuner) and the normal tuner.
Nolia is offline   Reply With Quote
Old 05-09-2009   #2
The new Sky white card no longer works in any current cam.
The Cyfra+ and Digi TV card should work in any multi cam, like the Dragon or Diablo, providing it is loaded with the right software, but I'm unsure if either of these cards are paired to official receivers, or the ability of the cams to update the card.
Have you got the new Digi TV card? It might be worth checking with your supplier regarding any limitations of the new card, including if you now require an official receiver, for updates.
Mickha is offline   Reply With Quote
Old 05-09-2009   #3
Nolia's Avatar
old digi card. The cyfra works in any multi crypt box so as the digi one. so the dragon or diablo will work wonders i take it? I will invest in one of those. speaking of sky my new card arrived a few days ago....
Old 05-09-2009   #4
Digi TV will soon be upgrading their encryption so the old card will no longer work when they do.
Have you got a card programmer capable of programming a Fun 7 or Dragon Loader card, in order to upgrade the Dragon Cam.
If not you should think of getting a Cas 3+, which can program both Diablo and Dragon Cams, as well as cards.
Considering the total cost it might be worth considering getting a cheap Dreambox, or other linux based receiver, which is capable of reading the new Sky white cards, and other cards, but at present can't update the card with the stay alive command.
Old 08-09-2009   #5
Nolia's Avatar
I dont have a programmer my friend. I will see whats cost effective. I have a Sony Bravia coming this week coming from abroad it's more advanced than the UK versions it has a HD tuner in built etc. so thats why i want a CAM so I can put any card....
Old 24-09-2009   #6
Nolia's Avatar
will the al jazeera card work in diablo 2.3? i can get the Cam and prog for £120
Old 25-09-2009   #7
Amo Amas Amant Admin
Topper's Avatar
Ermm
Ok so you can buy it but you don't seem to realise the futility of asking that question, the TV might not recognise the cam you put into it for starters...... also since you are intending using a non UK TV it is optimistic to say the least to think that someone else may have that specific combination of non UK TV, cam and card, whatever your final combination turns out to be, a number of cams are not recognised by stb's especially the multicrypt ones
Formerly toppervte33h
Show Your Support
by clicking the button
Thank you.
Freddie Flintoff is back
cam
