Which CAMs open what at present ?Satellite TV support fourm for X-CAM, Ultra CAM, Dragon CAM, Diablo, T Rex. | |
| Regular Member Join Date: 23-04-2009 Location: Dublin
My System: 1M Motorised Dish, DM 500s, Digital+, Sky+, TDT |
-------------------------------------------------------------------------------- Hi, I am about to buy a CAM and wanted to ask for opinions on which is the best one. Basically what CAMs open what packages etc ? I am on 16E at the moment but in the process of purchasing a 3 degree mono to access 13E or 19E also. But if there is CAMs opening better packages on different satellites then please tell as a motor could be in order if worth it. Thanks | ||
| Grimm Member Join Date: 08-03-2009 Location: Blackburn, Lancs
My System: 1.1m Triax Motorised 45e-45w, Raven 60cm fixed, Fortex Zeta PVR, Technomate TM500 | Same answer as on TW, Digi TV on 1w is the only thing open atm. That will be gone soon as they are in the middle of a card swap. | ||
| I've booted up, I've patched in, I'm online, offline, downloaded and extremely cheesed off! | |||
| Specialist Contributor Join Date: 09-09-2008 Location: Republic of Georgia
My System: Covering 30W-105.5E range, two motors, C and Ku band. Various receivers/cards/cams/etc. | diablo opens euro1080 from 9E and C+ NL certain channels from 19E | ||
| | #5 | ||
My System: 1M Motorised Dish, DM 500s, Digital+, Sky+, TDT | Is there a new CAM onn the way out before Xmas which can possibly open alot more than what is on offer now. I am presuming that Premiere/Sky Germany will no longer be available if they switch to NDS ? | ||
| | #6 | ||
My System: Covering 30W-105.5E range, two motors, C and Ku band. Various receivers/cards/cams/etc. | I have no idea about CAMs, but presently there are some CARDS, which oppen quite interesting stuff from 13E or 9E.... | ||
| | #7 | |||
Blog Entries: 1 My System: Sky UK. FTA analogue & digital satellite from 6 fixed dishes (5E/7E/9E/10E/13E/16E/ 19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S ![]() The last noble sat warrior to fly the olden flag of Analogue |
Sky Germany is already transmitting in NDS, althogh they havent finished turning off all the old encryptions yet. No chance of them becoming available again. | |||
| | #8 | |||
My System: 1M Motorised Dish, DM 500s, Digital+, Sky+, TDT | | |||
| | #9 | |||
| | #10 | ||
| Member Join Date: 09-04-2009 Location: Buckinghamshire(H.Wyc)
My System: Moterk 2100a motor on 80cm dish,16'E-18'W Manhattan XT-CM receiver. Fixed Sky dish 28'2E | which is better of the 3 in descending order?? Dragon CAM / T-Rex CAM v4.1 or Matrix Reloaded orMatrix Revolutions and Diablo CAM Light v2.3 ??? is it easy to decrypt al jazeera? | ||
| | #11 | ||
Blog Entries: 1 My System: Sky UK. FTA analogue & digital satellite from 6 fixed dishes (5E/7E/9E/10E/13E/16E/ 19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S ![]() The last noble sat warrior to fly the olden flag of Analogue | Its very easy to decrypt Al Jaz - you just need a subscription card. Matrixes are old hat and apart from reading cards dont have any practical uses for decryption these days. | ||
| | #12 | ||
My System: Moterk 2100a motor on 80cm dish,16'E-18'W Manhattan XT-CM receiver. Fixed Sky dish 28'2E | so the dragon and diablo which is better Sir/Madam?? i will have to get a subscription card in the next 48hrs. Is Digi tv easy?? | ||
| | #13 | ||
Blog Entries: 1 My System: Sky UK. FTA analogue & digital satellite from 6 fixed dishes (5E/7E/9E/10E/13E/16E/ 19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S ![]() The last noble sat warrior to fly the olden flag of Analogue | Digi TV is temporarily open - its changing its encryption in the near future and will dissappear soon. Could have gone by the time you get your kit set up! ![]() Dunno which is the best - I suspect its the diablo although I havent really been keeping up with the cam scene as they hold no interest to me. | ||
| | #14 | ||
| Super Moderator Join Date: 10-12-2004
![]() | It's not just the Cam you have to buy, you also need either a Cas 3 to update the Diablo, which can also update the Dragon. Or a card programmer and loader card to update the Dragon Cam. I wouldn't buy any cam at the moment. | ||
| | #15 | ||
My System: Moterk 2100a motor on 80cm dish,16'E-18'W Manhattan XT-CM receiver. Fixed Sky dish 28'2E | so if i was to buy a Al Jazeera card or ART Arabesque will that work in a multi crypt receiver gentleman? | ||
| | #16 | ||
| Manic Midlander Moderator Join Date: 24-09-2006 Location: West Midlands. UK
My System: Dreambox 7020si, Technomate TM600, Technomate TM9100 Fracarro Penta 85 Dish, Televes 0.6dB Quad lnb, TM SG2200 motor. 60cm Channel Master BSB dish on 28e, Mti Blueline 0.2db Twin Lnb. Rover ST-4 Meter Cyfra+ Subscription | It will probably work but as far as i am aware neither cam will activate the card correctly so it gives the full 12 months ![]() You need a proper Viaccess cam to activate these cards to the full 12 months ![]() ![]() Nano | ||
Sanity is nothing more than an excuse to be boring <<<<<<<<****** Dreambox DM7020 Si , S.I.F 1.9.3d ******>>>>>>>>> <<<<<<<<******** Technomate TM9100, EDG 4.4 ******** >>>>>>>> <<<<<<<<<<******* Technomate TM600, UR 23 *******>>>>>>>>> | |||
| | #17 | ||
| Regular Member Join Date: 04-09-2006 Location: Kent, UK
My System: Sky; Raven 90 multi-LNB 1W, 7E, 9E, 13E 16E, 19E; 1m Orbital dish on Moteck SG2100 motor; Technomate 1500, Phoenix Apollo and Kathrein (analogue) etc etc Receivers | Over the last year, I used (including activating) an ART Arabesque card in a Technomate 1500 without any problem for the full year; don't know about JSC though. | ||
| | #18 | ||
My System: Dreambox 7020si, Technomate TM600, Technomate TM9100 Fracarro Penta 85 Dish, Televes 0.6dB Quad lnb, TM SG2200 motor. 60cm Channel Master BSB dish on 28e, Mti Blueline 0.2db Twin Lnb. Rover ST-4 Meter Cyfra+ Subscription | Yes my mistake, Art are still using the older Via 2.5 cards. The new JSC Via 3.0 cards will only activate correctly in a Viaccess cam | ||
| | #19 | ||
| Regular Member Join Date: 09-02-2008 Location: Ireland
My System: -DM800 fixed on 28.2-quad -DM7020 motorized -Skystar HD2 motorized -Cards&Cams&Cas | redout, consider buying a linux box with card reader. Much more flexible and future proof! | ||
| cams, open, present |
