List of compatible receiver for diablo wifi?Satellite TV support fourm for X-CAM, Ultra CAM, Dragon CAM, Diablo, T Rex. | |
| Specialist Contributor Join Date: 25-04-2005 Location: Austria
My System: 1,25 Fibostop Jäger Smr 1224 & Smo 36 Dual Axsis Motor Dynasat F1 Monterey 140 Drembox 800 sky Pace HD Box Tagra 2,20 M Fullsize Dish Echostar 2,40m Mesh for cband! |
Hello! on the net i read,not every receiver,will be compatible,with the wifi cam,does someone have a list,of non compatible stbs? the configuration is now finfinish,i have connection to my router,light of wlan and on the diblo is flashing but still not working,currencly i try on old echostar ad 3000,can anyone confirm,about the compatibly of this receiver? also many stbs has problems,when the tuner is not protected enough,from the wlan signals of diablo,then picture freeze,would be good when we can make here a list ,what stb work good,and the non compatible ones! thanks for your input! | ||
| Specialist Contributor Join Date: 09-09-2008 Location: Republic of Georgia
My System: Covering 30W-105.5E range, two motors, C and Ku band. Various receivers/cards/cams/etc. | There are several lists, but most of them are fake. Personally, I can give list, verified by me personally: Ctech 5000Combo + - ok Openbox X-820 - ok Comag SL65 2CI - ok Octagon SF918HD - NOT WORKING (pixelization, choppy audio). | ||
My System: 1,25 Fibostop Jäger Smr 1224 & Smo 36 Dual Axsis Motor Dynasat F1 Monterey 140 Drembox 800 sky Pace HD Box Tagra 2,20 M Fullsize Dish Echostar 2,40m Mesh for cband! | thank you! does this pixels only coming when you watch over ccam,or also in the emu mode? in echostar 3000 the cam gets very hot,i dont use it again there! | ||
| compatible, diablo, list, receiver, wifi |
